Where to find a panel mount mini-USB socket? — Parallax Forums
john_sjohn_s Posts: 369
edited 2013-04-19 09:29 in General Discussion
I need some help in finding this exotic item.
I've been trying to find a panel mount female mini-USB receptacle that will also connect to the mini-USB port located few inches apart on the board.
In other words a Female mini-USB to male mini-USB on a short cable.
Anyone have any ideas or sources? I haven't found one yet!
    edited 2013-04-18 21:46
    Panel mount USB sockets are made by amphenol. You can search on digikey or mouser. But due to their IP67 rating, they also have aircraft prices :)
  • john_sjohn_s Posts: 369
    edited 2013-04-18 22:31
    Yeah, I did google search and found those but I do not need IP67, just a very plain one is ok.
    I also found plenty of standard type A panel mounts but NOT a single that uses mini-USB receptacle.
    I'm almost tempted to build those few that I need using a surface mounted mini-usb socket and add a pigtail with another matching plug.
    edited 2013-04-19 02:19
    You can buy pc bracket mounted usb sockets, buy mini usb receptacle and solder by yourself.
  • RDL2004RDL2004 Posts: 2,554
    edited 2013-04-19 05:40
    Bulgin makes some that aren't too expensive, but you may have to do some soldering to fit your needs.
    http://www.mouser.com panel mount mini USB connectors
    edited 2013-04-19 08:28
    Thank you all for good suggestions that confirm that there's nothing available off the shelve and then "some assembly's required" :)
    I guess I go this way https://www.sparkfun.com/products/9966 and attach a short cable with mini-B plug to it.
    edited 2013-04-19 08:52
    How about something like this:
    The panel part is B, not mini-B, but it terminates in a mini-B male to your board. It's just as easy to run an A->B cable from your PC as it is an A->mini-B cable.
    Yes Phil, I found that one nearly perfect ... I still wonder what makes it that there's no mini-USB panel combo like the one shown in adafruit link.
