XBee configuration
I just ordered an XBee starter set and have been doing some reading up on it. I've got a project in mind and am wondering if when changing the interface speed from 9600 baud to something high is that change saved in flash on the XBee or will I need to make the changes at every power up or reset.
If you opt for the 115200 setting, be aware that what you get is actually closer to 111111 baud.
I will be shooting for 115200 baud. I hope the timing of 111111 baud is close enough for what I'm going to be doing.
I hoping to use these with the Radio Shack Color Computer and a PC using software package called drivewire. The idea is to have the PC (anything running Java) act as a virtual harddrive for the Coco and transfer the data via a serial port on the coco. It's working well but naturally needs a wire between the coco and pc. My hope is that I can replace the wire with a couple of XBee modules. My hope is that I'll be able to configure the XBees and plug them in and it'll work.
The only flow control available on the Coco is CD (carrier detect). Since the "other end" will be to a PC via USB my hope is that speed, timing, etc won't be an issue. Right now the software that runs on both ends is "spray and pray". For the purposes of the testing I think we'll just start using slow data rates and increase the rate until the Coco can't keep up or we have problems because of baud rate mismatches.
