Propeller Roaming with ping — Parallax Forums
AndroidAndroid Posts: 82
edited 2013-04-08 15:13 in Propeller 1
Could someone please post the source code for roaming with ping on the propeller.
-Android
    edited 2013-04-07 18:58
    See this thread for a version of BoeBotBasic (FemtoBasic) for the Propeller Board of Education on a BoeBot chassis with the PING sensor on its servo bracket. This includes a Basic program translated from the Stamp's Roaming with PING program. You can use the version of BoeBotBasic with an xBee module to do wireless programming (in Basic) with a PC or Mac as the console. You may need to recompile BoeBotBasic to specify the I/O pins to be used for the xBee (instead of the USB serial port).
  • AndroidAndroid Posts: 82
    edited 2013-04-07 19:04
    Thank you once again Mike!
    -Android
    edited 2013-04-07 19:10
    Hey one last thing! What ports are the motors and ping supposed to be plugged into on this code?
    edited 2013-04-07 20:47
    Here is the Ping Demo code that I am using on my Stingray with the MSR1 Propeller Control Board and 3 Pings.
    edited 2013-04-07 20:58
    @Android, Read the documentation file in the .ZIP archive. There are binary files for both using the USB port and an xBee for the Basic console.
    Ok Mike thank you very much!
