Memory Stick Datalogger 27937 SPI mode — Parallax Forums
bayuprioritybayupriority Posts: 2
edited 2013-04-09 00:57 in Learn with BlocklyProp
hi everyone,
im having problem with Memory Stick Datalogger 27937.
now im working with microcontroller atmega32 and im using code vision AVR.
i want to create file .txt from the microcontroller to the flash disk via Memory Stick Datalogger 27937.
i use SPI mode between datalogger and microcontroller,
and now i got little dizzy because i dont find any information abaout D7-D0 like the picture below (red circle) on datasheet.
please help me to find the answer, thank you :)
    edited 2013-04-08 05:26
    D7 through D0 are just the data bits of one byte, with the highest bit, D7 going first. You are sending the data serialized over the SPI one byte at a time, but there is always the possibility of some confusion about D0 or D7 going first.
    The diagram shows how all the signals related to SPI are expected to interact.
  • bayuprioritybayupriority Posts: 2
    thank you for your answer loopy,
    so D7-D0 just the data bits? how about the address?
    honestly, it is my first time using datalogger. have you any link or something about this datalogger?
    i have read the pdf but i could not find the answer
