TDA 7052 - Low volume?
Hello there,
I've just made my first simple WAV player prototype, but it's not fully perfect until I have a louder amplifier.
So, I have here are the 7052s and the volume is quite low when it's on a 6V supply. The input is from the PWM DAC from the microcontroller. With the lower volume, there's a bit of noise.
Then I connected to +12~13V supply (two used 9V batteries combined), it's significantly louder and lesser distortion.
Could I connect the 7052 to a +12V AC-adaptor with 1.2A current? I checked the datasheet - I can't seem to find the max.current specs there.
Also, I'm using the 8ohm 0.25W speaker. If I connect it to a 1W speaker, could it be much louder?
Pardon my ignorance on audio systems - I'm in the midst of studying them.
I've always had plenty of volume from the TDA7052 at 6V. They won't fill a room, though. Post your schematic, you might have it connected wrong.
I've been working some with that amp lately but have not noticed any problems with low volume or distortion. In fact, even with a 5V supply, I get good volume from a 6W-rated 8-ohm speaker. (I've even managed to blow out a couple mini 0.25W speakers with it, so you have to be careful what you connect it to.) Did you follow NXP's recommended schematic? How have you fed the DC volume control input? Also, it's very important to put your speaker in an enclosure. You will never get good volume from an unenclosed speaker.
I followed the recommended schematic - including the two filter caps at the supply.
The sound which came out from the speakers are ok, but I had to touch the negative terminal of the speaker just to hear a much more clearer sound. If not, it's fuzzy. By the way the prototype is temporary and I used crocodile clips which connects the speaker to the breadboarded circuit.
However, it didn't fill up the room that much. Maybe I need a higher bitrate WAV, or I need a bigger speaker.
Btw - it's for designing a decoration, which is Christmas, and this is also expandable to the upcoming Chinese New Year, except it's in a red cardboard lantern.
However, it's still not loud enough, despite it's 6~7V on the battery. I do not know why upon 7V above, the amplifier isn't working as the max. supply voltage is actually 18V.
Must I use a more powerful power amp like the other TDA series, or should I use a bigger speaker?
It's only a 1 W amplifier. You will have to use a higher power device if you need more volume.
Btw, the loudspeakers I have now are only 0.25Watts.
Any other TDA series you could recommend for higher output?
The TDA2030H delivers 14W, which should be more than enough! I've used it in a design and it worked very well, with good audio quality, but don't try it on those little speakers, they will probably explode. It needs quite a few external parts, though. I've got a PCB design somewhere for it, and the PCB I made.
Right now I have the TDA7052 - they are much expensive than the LM386, but saves me a lot of trouble from adding the external components.
I'm building a small decoration unit which plays music in my living room, so I just need to fill up the room a bit.
The TDA2030 also needs a dual-polarity PS, I used a mains supply delivering +12V and -12V. Batteries won't last long.
Fortunately I'm using an AC-adaptor for the decoration. I've seen one person actually did 12V on the TDA7052 without a heatsink - he is using all AA batteries.
I wonder if I could do the same on the AC adaptor. Let me check the datasheet again...
1) What code are using to play your audio?
2) What resistor/capacitor values are you using on your input signal between the prop and amp?
3) Is the wav data normalized to a sufficient amplitude? Can you hear the same file in other applications at a typical volume level?
To answer the question,
1.) I used the simple PWM + WAV decoder in a microcontroller.
2.) It's only 1k and 100nF.
3.) I'm not sure of the normalization. Clearly, I could hear the sound from the speaker a few inches away from the speaker. If I'm 3 meters away from the little speaker, can't hear that much. It's audible, but not loud enough to fill up the whole room.
I guess it is the limitation of the speaker. Let me ask some other occupants of my home to judge the sound of the decoration.
Don't give up on the TDA7052 yet. I routinely produce volumes that are uncomfortable to experience using such small speakers as mentioned above. Again, I don't know the exact nature of your requirements, but I suspect when you get it dialed in correctly it'll be plenty loud for you.
Initially we planned for the music of the decoration should fill up the whole room, but due to the small speakers and only limited amount of voltage, it's as loud as the loudest greeting card only.
On quieter time, the music is very audible and clear, only during mornings (household activities and conversation sounds from people) the sound may be diminished.
We are trying to make it blare a Chinese New Year song, and some sounds of firecrackers just to have the atmosphere, but the nature of the festive season at home is often noisy as visitors are always around, so I know it could be a limitation there unless I changed the speakers and have a bigger amplifier.
The decoration, however could be fine in Christmas due to the quieter neighbourhood during the season.
The TDA7052 is plenty powerful to fill a room with sound. You just need the right speaker with an enclosure. I cannot emphasize the enclosure aspect enough. You simply will not get sufficient volume from any speaker that's not housed in a proper enclosure.
So the enclosure will be in a form of a plastic box? It's usual to drill some holes for the sound to come out from the enclosure?
Anything you can do regarding an enclosure is better than nothing -- even a cardboard box. If you don't believe me, cup your hands around your naked speaker while it's producing sound and note the difference in volume and tone!
can i replace my speaker of 2watt 8 ohm to 10watt ohm
By the way, double posting is a Forum no-no so you're original message has been removed.
Find the Forum guidelines here:
http://forums.parallax.com/showthread.php/134682-Forum-Guidelines
Also, please know that this thread is over two years old. You might want to start a separate one.
IIRC, there are two variants, the 7052A and 7052B which had electronic volume control. So double check which you are using and make sure you have it connected correctly. Have you got the input AC coupled? A simple forum etiquette is that when you have problems like these you should supply a schematic and if possible a photo or two.
BTW, with the speaker it's not so much about having a proper enclosure but having a baffle.
Oh yeah, it was the double post that caught me, I still hadn't had my morning coffee (decaf)
