Can the new product, XBee 900HP Module and Antenna, be used without a license? — Parallax Forums
ElectricAyeElectricAye Posts: 4,561
edited 2014-02-02 09:00 in General Discussion
I saw the new product listed in the Announcements, and it has me wondering if any kind of license is needed to run this thing, especially with the antenna, etc. attached to it.
http://forums.parallax.com/showthread.php/146956-New-Products!-XBee-900HP-Module-and-Digi-900-MHz-Antenna?
  • CircuitBurnerCircuitBurner Posts: 21
    edited 2013-03-28 19:09
    I dont see a problem with non licensed use in the USA as long as you arent transmitting watts. Not sure right offhand what the limit would be, Im thinking a watt maybe. 900mhz in the US falls into a public sector general use frequency band, and there are several others.
    I fly UAVs and long range FPV aircraft using 433 mhz UHF band equipment with a 50 mile range or more (if using my yagi-beam antennas on ground station.) and that requires my Ham license...a killer benefit for it.
    Getting your Technician class Ham license is not hard if you are already into electronics and willing to study a little for the test.
    Anyone seriously interested in that drop me a line (message/email) and I will tip you on the shortcut to fast track this process.
    Radio is freekin cool! lol
  • NWCCTVNWCCTV Posts: 3,629
    edited 2013-03-28 20:04
    Correct me if I am wrong but aren't cell phones on the 900 Mhz frequency? And also, I thought scanners are banned in the US from using 900 Mhz because they are able to pick up cell phone coversations. Which, by the way is why people go to Canada to buy them.
    edited 2013-03-28 20:24
    I've got a ham license and this band looks like it's in the ham band. http://www.arrl.org/files/file/Hambands_color.pdf
    But I think this band also gets shared for ISM, Part 15 blah blah blah, which dictates the thing run at some low power if you're doing it unlicensed. Where it gets crazy is when you stick an antenna on it, at which point it gets into the problem of so many microvolts per meter emission, etc. and that's kinda what I was wondering about. What's the wattage output or microvolt/meter output for something like this, especially with an antenna attached?
  • doggiedocdoggiedoc Posts: 2,255
    edited 2013-03-29 03:26
    A Ham license is on my bucket list. And this product would be a good excuse to get one (even if not required to operate).
    Paul
    edited 2013-03-29 04:36
    There is indeed a recent opening of a segment of the 900mhz range for Amateur Radio, not sure without looking exactly what range it is, but a large portion of this band is like I said, general use for non licensed usage (appliances) for public.
    Yes, there are slices reserved for government and cell phones, but these are slowly migrating away into the faster frequencies in the microwaave spectrum, and so arent exactly enforced very strongly, unless there is compaints or issues created by someone interfering with operation of important services or coms.
    Personally, I think its a crowded, and noisy section of spectrum and never been very interested in it for any particular reason.
    Any place near band sections containing Bazillions of houshold telephones or consumer appliances tend to repel me from that region, if only for its potential for reciprocating spurrious harmonic emissions.
    I have always gravitated toward longer wavelengths, and esp nowadays since much of that spectrum has been vacated for higher frequencies...I guess im biased in a way too because of past Ham activities down below 30mhz...down into the 1.8 mhz realm of shortwave and medium wave and hte ability to shoot a signal anytime of the day or night around the globe to Mongolia or N.Z. / australia with 5 to 10 watts...that kinda has an affect on those who have worked those frequencies, lol
    But seriously, with my UAV piloting, and the limitations faced by operating above 1.2Ghz, the relative luxury of using Low UHF (430-460mhz) for long-range command and control has spoiled me big time.
    The only conflicting issue that keeps me from utilizing longer wavelengths for stuff other than raw communications (station to station) is the requisite antenna dimensions for longer wavelengths. And, they can become daunting discouraging issues too, when the required antennas involve hundreds of feet of wire, or loading coils and traps that are bigger than my torso.
    Ah...I still wonder about the early early days, the days of marconi spark gap transmitters...those super wide-band contraptions that could be worked globally with ease...morse code -in clicks- ...lol
    <shakes head awake>
    Use something like that now, and you trash everything up and down the spectrum from Dog-audible VLF to these low microwave regions we are debating today...in wide random swaths of harmonic horror.... Police knocking at my door, dispatched by FCC, DHS, FAA, FBI, CIA, and angry cosmonauts who had a forced, unscheduled re-entry sequence because my spark-gap trasmissions rebooted their flight computers.
    Anyway, about that fast track to the tech license....here it is...and trust me, this is the chit...and it sounds too easy, almost stupidly, but Im not joking - this really is the easy fast way...www.hamtestonline.com , if youre real cheap just take the free version of the study exams, as they are at minimum 80% of the actual FCC pool questions. I literall couldnt beleive it when I took my exam and recognized nearly all of the questions verbatim on that test. Its the ticket.
    edited 2013-03-29 08:40
    doggiedoc wrote: »
    A Ham license is on my bucket list. ...
    Since they did away with the Morse code requirement, all you need to do is take a written multiple choice test. It's pretty easy to get the first license, especially considering you get the entire pool of questions in the ARRL prep book:
    http://www.amazon.com/Ham-Radio-License-Manual-Arrl/dp/0872590976/ref=sr_1_1?ie=UTF8&qid=1364571528&sr=8-1&keywords=arrl+technician+class+license+manual
  • ajwardajward Posts: 1,130
    edited 2013-03-29 09:38
    I've looked at this product as a replacement for the 2.4 GHZ xbees on my Boe-Bot. Tried to set up the 'bot with a wireless camera to roam around the house. As I pretty much expected, with the xbees, camera and wireless router all on 2.4 GHZ, the whole affair sorta crashed... :lol:
    edited 2013-03-29 18:03
    Not sure about the camera, but you should be able to at least change the channel on your router. I did that when I had some interference with other devices and it did help. Some wireless cameras also have this ability but are normally the more expensive ones.
    edited 2013-03-29 18:18
    No license is required. Parts of the 900 MHz band are available for use under Part 15 of the FCC code for unlicensed use, with certain power and antenna restrictions with which the XBee complies.
    edited 2013-03-31 17:09
    the "900 Meg" band is not anything new at all! just that most ham gear is not made for it unlike " 440" and 2 meters ... As long as it is part 15 approved and you do NOT mod the device with a new or larger antenna . You are OK to use it as a normal citizen ..
    Granted a ham Tix is NOT a license to kill.... In fact You are now "Expected " to Be more proactive and more aware of radio law then kiddies on FRS HTs .
    Once you have your tix you can't claim ignorance .
    Also every thing you transmit has to include your call sign .... so to use a ATV ( ham tv ) transmitter you need to have a Video overlay or perhaps your call in the background . the Prop backpack can do this with Ease ! however now you cant just Build a transmitter and shove it on the air as in a Low power part 15 device can .....
    More work...
    Peter KG6LSE
  • trookstrooks Posts: 228
    edited 2014-02-01 11:53
    But seriously, with my UAV piloting, and the limitations faced by operating above 1.2Ghz, the relative luxury of using Low UHF (430-460mhz) for long-range command and control has spoiled me big time. <<< ..................
    Methinks you may be overlooking a really mean gotcha in that forest of regulations.
    - Only the government may operate UAVs out of their line of sight. -
    By the time you are using enough power to require a license you are likely at or beyond the range that could cost you that license and much more.
    That is why the latest Whoop Te Doo by Google was such a farce. Once that cute little chopper dropped below the tree line or behind a building out of view of the operator the law was being broken.
    Tim
    Experience allows you to recognize a mistake immediately after you make it again.
    more power for a craft on the uplink Means Less issues with loss of controll .. unless you have one heck of a IMU to stay aloft If you loose RF for a few Sec .
    Look no offeince to my mom as she is not tech savy but she managed to get her Ham call .......... ( for the record it was so she can set up ARDF transmitters for out T hunting in Cali . )
    Get a license and get some time to Learn RF and its laws then Play ! ......
    unlike the IRS tax code and the ACA . the geeks here can probably relate to the FCC codes and laws . Its a good book to read and will Really open up your eyes to the bigger picture of how RF is and why we have laws in place for it .
