Switching Power Supplies and Various Prop Boards
Hi guys,
Long time lurker... occasional poster here. I am fairly facile with the Propeller... basic electronics, not so much.
I have various long term projects...including a semi-autonomous wheelchair. The motors are 24V 15Amp. I have read that it is a good design practice to drive everything from a common source...i.e. the main batteries.
So, I have in my hands what I believe is a switching step down converter. http://www.ebay.com/itm/1-PC-OF-A-DC-STEP-DOWN-CONVERTER-MODULE-WITH-MULTI-FUNCTION-VOLT-METER-NICE-/261184848885?pt=LH_DefaultDomain_0&hash=item3ccfd483f5
I would like to feed 5V from this into a Quickstart board so that I can have 5V available at Vin. From other questions, it seems that this might not be healthy for the linear regulator of the QuickStart Board. True?
Alternatively, could I do the same thing to a Propeller Project Board?
Rich
Rich
I feed linear regulators with the output of buck converters all the time. In fact, ever since the advent of this guy, I do little else. Back in the day, a linear regulator would provide something like 30 or 40 dB of isolation from switching noise on Vin. I don't know what the LD1117v33 offers in this regard, but the combo certainly does work well.
You should change your name from "User Name" to "Public Services"
Rich
