Interface RFID Reader to USB Prop Plug Possible?
I would like to know if it is possible to interface the RFID Reader to the USB Prop Plug interface card? I know the RFID Reader requires 5VDC in order to work, hence my dilema. The next goal would be to get the Parallax Serial Terminal program to be able to read the RFID tags that came with the kit.
Thank you,
Jason Cramer
GySgt USMC (Ret)
Thank you,
Jason Cramer
GySgt USMC (Ret)
When I interface the USB RFID reader, not the Serial RFID reader, to the USB Prop Plug the USB RFID reader does not power up due to no 5VDC going through the USB cable. Since there isn't any power I'm unable to read the tags at the moment. I really don't want to break down and purchase the Serial RFID Reader. I apologize for not specifying in my original post that I am trying to interface the USB RFID Reader vice the Serial RFID reader.
Thank you.
Jason Cramer
GySgt USMC (ret)
AFAIK the prop plug uses a standard USB cable with a USB connector on the PC end and a miniUSB connector on the prop plug end. There is +5V going through the cable to provide power to the FT232 on the prop plug PCB. Unplugging the miniUSB connector from the prop plug PCB and plugging it in to the RFID reader should provide +5V to the reader.
Can you post the part number for your reader?
