embed txt file in index.htm ?
Thanks Mike G for some really brilliant work.
I am new to the Spinneret forum. I have had success implementing the tutorial, and can access my
Spinneret. I did stumble with the setup of my Belkin router but was able to overcome those issues.
I want to attempt the following project:
1. Write variables of sensor values once each minute to the SD card on the Spinneret board,
As a txt file.
2. Embed the txt file in Index.htm.
3. Every 24 hours erase the txt file and start a new one.
This will allow a view of a log the txt file over a 24 hour period each time the spinneret is
Accessed.
.I believe I have the skills to accomplish items one and three. I need help/direction with item two.
Is it possible to embed at txt file in Index.htm or is there an easier way to accomplish this.
Thank you!
Larry
As a txt file.
Accessed.
Thank you!
Larry
If you want to do something fancy then you'll need to HTMLize the txt file on the fly.
I spent about two days trying all kinds of exotic solutions before posting.
Larry
In regards to your message:
For a simple SD card file creation, you might try something like the following:
(Note: the FileExists method is a method down towards the end of the HTTPServ spin file.)
Now, this same concept can be used with variables:
Now you've got the concept for storing sensor data to an sd card... put the data into a variable, write it to the file and voila! Better than sliced bread on a stick.
You can certainly get much more fancy than this, but it's a good foundation to start with. If you have lots of sensors, and they are all giving some kind of decimal value, you can reduce your coding by using a repeat loop:
Amazing device. I constantly find myself jumping three steps ahead with coding, only to crash and burn
Due to my lack of knowledge. I will modify my code with your examples and see where it leads me,
Thanks again.
Larry
Also- one thing to note in the examples above.... if the file already exists, it does nothing. It's sort of a one-shot as it's written. To RE-write the file, simply add the line "SDCard.deleteEntry(@logfile)" as follows:
Again, this is very crude... but good to tinker with until you get the hang of it.
