embed txt file in index.htm ?
Thanks Mike G for some really brilliant work.
I am new to the Spinneret forum. I have had success implementing the tutorial, and can access my
Spinneret. I did stumble with the setup of my Belkin router but was able to overcome those issues.
I want to attempt the following project:
1. Write variables of sensor values once each minute to the SD card on the Spinneret board,
As a txt file.
2. Embed the txt file in Index.htm.
3. Every 24 hours erase the txt file and start a new one.
This will allow a view of a log the txt file over a 24 hour period each time the spinneret is
Accessed.
.I believe I have the skills to accomplish items one and three. I need help/direction with item two.
Is it possible to embed at txt file in Index.htm or is there an easier way to accomplish this.
Thank you!
Larry
As a txt file.
Accessed.
Thank you!
Larry
If you want to do something fancy then you'll need to HTMLize the txt file on the fly.
I spent about two days trying all kinds of exotic solutions before posting.
Larry
In regards to your message:
For a simple SD card file creation, you might try something like the following:
(Note: the FileExists method is a method down towards the end of the HTTPServ spin file.)
pub Create_log SDCard.closeFile 'This'll close the file if it's open and does nothing if it's already closed... either way, it's closed after this. If not (FileExists(@logfile)) 'If the filename in logfile doesn't exist on the sd card, let's create it and write something to it. SDcard.newfile(@logfile) 'Create the new file SDCard.openFile(@logfile, "W") 'Open in it WWWWWWWrite mode. SDCard.writeString(@test1) 'Write the stuff in test1 to the file. SDCard.writeString(String(13)) 'Stick a carriage return after it. SDCard.writeString(@test2) 'Write another chunk o' stuff. SDCard.writeString(String(13)) 'What? another carriage return??? no way!! SDCard.closeFile 'Good enough for now... close 'er up! DAT logfile byte "Mylog.txt",0 test1 byte "This is the first test!",0 test2 byte "This is the second test!",0Now, this same concept can be used with variables:
VAR long MyArray[3] pub Create_log MyArray[0]:=123 MyArray[1]:=456 MyArray[2]:=789 SDCard.closeFile 'This'll close the file if it's open and does nothing if it's already closed... either way, it's closed after this. If not (FileExists(@logfile)) 'If the filename in logfile doesn't exist on the sd card, let's create it and write something to it. SDcard.newfile(@logfile) 'Create the new file SDCard.openFile(@logfile, "W") 'Open in it WWWWWWWrite mode. SDCard.writeString(@test1) 'Write the stuff in test1 to the file. SDCard.writeString(String(13)) 'Stick a carriage return after it. SDCard.writeString(@test2) 'Write another chunk o' stuff. SDCard.writeString(String(13)) 'What? another carriage return??? no way!! SDCard.writeString(String("First long= ")) SDCard.writeDec(MyArray[0]) SDCard.writeString(String(13)) 'Stick a carriage return after it.... hate those carriage returns! SDCard.writeString(String("Second long= ")) SDCard.writeDec(MyArray[1]) SDCard.writeString(String(13)) 'Stick a carriage return after it. SDCard.writeString(String("Third long= ")) SDCard.writeDec(MyArray[2]) SDCard.writeString(String(13)) 'Stick a carriage return after it. SDCard.closeFile 'Good enough for now... close 'er up! DAT logfile byte "Mylog.txt",0 test1 byte "This is the first test!",0 test2 byte "This is the second test!",0Now you've got the concept for storing sensor data to an sd card... put the data into a variable, write it to the file and voila! Better than sliced bread on a stick.
You can certainly get much more fancy than this, but it's a good foundation to start with. If you have lots of sensors, and they are all giving some kind of decimal value, you can reduce your coding by using a repeat loop:
VAR long MyArray[583] pub Create_log| iter 'iter means iteration! MyArray[0]:=123 MyArray[1]:=456 MyArray[2]:=789 'on and on until we have a value in all 583 longs... SDCard.closeFile 'This'll close the file if it's open and does nothing if it's already closed... either way, it's closed after this. If not (FileExists(@logfile)) 'If the filename in logfile doesn't exist on the sd card, let's create it and write something to it. SDcard.newfile(@logfile) 'Create the new file SDCard.openFile(@logfile, "W") 'Open in it WWWWWWWrite mode. SDCard.writeString(@test1) 'Write the stuff in test1 to the file. SDCard.writeString(String(13)) 'Stick a carriage return after it. SDCard.writeString(@test2) 'Write another chunk o' stuff. SDCard.writeString(String(13)) 'What? another carriage return??? no way!! repeat iter from 0 to 582 SDCard.writeString(String("Long ")) SDCard.writeDec(iter) SDCard.writeString(String(":")) SDCard.writeDec(MyArray[iter]) SDCard.writeString(String(13)) 'Stick a carriage return after it.... STILL hate those carriage returns! SDCard.closeFile 'Good enough for now... close 'er up! DAT logfile byte "Mylog.txt",0 test1 byte "This is the first test!",0 test2 byte "This is the second test!",0Amazing device. I constantly find myself jumping three steps ahead with coding, only to crash and burn
Due to my lack of knowledge. I will modify my code with your examples and see where it leads me,
Thanks again.
Larry
Also- one thing to note in the examples above.... if the file already exists, it does nothing. It's sort of a one-shot as it's written. To RE-write the file, simply add the line "SDCard.deleteEntry(@logfile)" as follows:
SDCard.closeFile 'This'll close the file if it's open and does nothing if it's already closed... either way, it's closed after this. SDCard.deleteEntry(@logfile) 'This'll get rid of the file so you can re-write to it. If not (FileExists(@logfile)) 'If the filename in logfile doesn't exist on the sd card, let's create it and write something to it. SDcard.newfile(@logfile) 'Create the new fileAgain, this is very crude... but good to tinker with until you get the hang of it.
