I'm having a problem getting the prop connected to the vr shield. I tried the "SayItDriver_VR" from the obex, but i think it's missing rx,tx, baud assignments in the con section. I tried to add them but there are global variables with the same names. Nothing is showing up in the debug terminal, i have the baud set to 57,600 for the terminal window as it says in debug .start. Also I tried switching the rx, rx lines from prop to vrshield. If anyone can clue me in on the setup i would appreciate it. Thanks
