Si1143 Proximity Sensor — Parallax Forums
LeonLeon Posts: 7,620
edited 2013-03-18 10:24 in General Discussion
I've just ordered one of the new Si1143 Proximity Sensor units:
https://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/28046/List/0/SortField/4/ProductID/874/Default.aspx
I wouldn't have known about it unless I'd seen a tweet from Parallax.
I'll be trying it out initially with a Propeller.
Is anyone else getting one? I think that the new Microchip device is superior, but it will be some time before it is available.
    edited 2012-11-23 07:30
    This one's a proximity sensor, the other one calls itself a gesture sensor. Probably very different in use. I'm guessing that three IR or sonar distance sensors might be better for sensing large gestures. What's the price on the Microchip unit?
  • LeonLeon Posts: 7,620
    edited 2012-11-23 07:40
    The Si1143 is also intended for gesture recognition:
    http://www.silabs.com/products/sensors/infraredsensors/Pages/Si114x.aspx
    The gestures seem rather limited, though.
    Pricing isn't available yet for the new MGC3130, but it looks as though it will be more expensive than the Si1143.
  • Ken GraceyKen Gracey Posts: 7,416
    edited 2012-11-23 08:16
    Thank you for the order, Leon. This sensor took a while to develop and it works as specified. I'll be interested to know what you think as one of the early adopters.
  • W9GFOW9GFO Posts: 4,010
    edited 2012-11-23 13:27
    That looks like a really cool device. I am having trouble finding what it's range is though.
    edited 2012-11-23 14:02
    It depends on the objects it's detecting and the ambient lighting. I think it's a couple of cm for a finger tip.
    I've just ordered some 5-way right-angled connectors, which will enable me to plug the assembly into a Proto board. I should get them on Tuesday, and I'll construct the interface so that I'll be able to test the unit as soon as it arrives.
    edited 2012-12-05 04:34
    The unit has just arrived. I'll interface it to one of my Propeller Proto boards and see if I can get it doing something.
  • cristobalcristobal Posts: 1
    I'm trying to use this sensor with an Arduino microcontroller but it can't get it to work...
    any ideas?
    thanks! from Chile
