8-pin SO8 to DIP for bread board testing ...
Beau Schwabe
...I'm sure they exist, right? I've always been a cheap skate and made one myself, but what a P.I.T.A. ...this time around, the third attempt was a charm. Fortunately I ordered Ten IC's and at the moment I only need One.
I was just wondering if such a beast existed, I don't know that I've ever seen one.
Edit: Well, I did find two different versions on E-bay, but they both look like they have a bigger footprint than what I was able to do by hand. Hmmmm
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 6/6/2010 8:27:08 AM GMT
Beau Schwabe
IC Layout Engineer
http://www.epboard.com/eproducts/protoadapter.htm
Check out the Propeller Wiki·and contribute if you can.
www.mouser.com/ProductDetail/Bellin-Dynamic-Systems/B516/?qs=sGAEpiMZZMviNQmaL%2fXs4vW7tjGJ%252bLM1
The boards are well-made and easily snap from the panel. The adapters come in other flavors as well.
"Nice soldering job on such a tiny part!" - Thanks, but I can tell that my eyes are getting older. 12 years ago I soldered small stuff like this all the time and could do a better job without wearing any glasses or using a magnifying glass, now if I didn't have glasses there wouldn't be a snowballs chance in HE{double toothpicks} ... most of it is technique though. i.e. the small wires are soldered to the IC before it's ever put into position, and THEN the wires are soldered to the .1" pins.
Beau Schwabe
IC Layout Engineer
cgi.ebay.com/SOIC-adapter-boards-SO-8-SMT-8-pin-DIP-set-5-/280458264945
Also available in 3s and 4s, just check my other items.
- Rick
- Rick
www.futurlec.com/SMD_Adapters.shtml
Unfortunately everything including their soic8 are for 0.6" instead of 0.3" spacing
Sending $20 on a good mix of adapters has been one of the best investments I ever made. I've tried soldering a 100 pin TQFP LPC to get a feel for what prototyping with the prop2 will be like
Jim
I've actually sold about 800 since I first started last spring. I had to re-list a few times because even if you select "good until canceled", eBay will still end it if you let the quantity available drop to zero.
These little boards are very small and light, and since I don't include the header pins I can just mail them in a regular envelope like a letter. First Class Mail usually only takes a few days to get anywhere in America. That's probably the only reason people buy them. You can get similar items from overseas for a little cheaper, but they take weeks to arrive.
- Rick
SOP8-SOIC8-SO8 ZIF Socket Adapter:
Im more interested in just the black adapter socket on its on so I can find other sizes and make my own boards, but if Mouser has the whole units sold as is, thatd be okay too I guess.
http://www.mouser.com/Connectors/IC-Component-Sockets/_/N-211lk?P=1z0wxos&Keyword=SOIC+socket&FS=True
I still sell the plain boards (the link in the previous post is out-dated).
http://www.ebay.com/sch/1518kyt/m.html
You can get them cheaper from China or Thailand, but mine usually arrive in just a few days.
Did you try: http://www.schmartboard.com/
dgately
The socket adapters I just went ahead and bought a couple from China for less than $5. Ill work with the solder kind first. Now to find the art number at Mouser for the pin header strips...
Yeah, that would be me
At one time I tried selling the boards with the header pins included, but I couldn't send them in a letter, the Post Office's machines just tore them up. I'd have to use a padded envelope and that would add over $2 to the total cost just to cover the higher shipping cost and the cost of the envelope. That would be in addition to the cost of the pins themselves.
There is a general trend to stock the larger-superset ZIF, so for 8 pin 150 mil, that would be SO16N
You'll see the plastic is all 16 pin based anyway.
These are something I had not seen before :
http://www.aprilog.com/ZIF_SOICpads.html
- it is a ZIF socket plus a stalk-plug-SMD 'foot' - quite nifty, but the leverage would worry me a little.
I guess you remove the whole unit, to replace the chip, then carefully replug ?
they also sell just the ZIF,
http://www.test-socket.com/index.htm#652B0082211
and $8.00 seems a good price.
Pin header search at Mouser
Funny, Id never before thought of coming to the Parallax forum for help. I literally live down the street almost from their Rocklin, CA headquarters and their Basic Stamp was my first intro to micro-controllers back in '94. I should have been hanging around here long long ago.
Another great idea
I use these guys for great machined headers for my adapter work.They work great for bread boarding. Free Shipping!
http://www.ebay.com/itm/Machined-Pin-Header-male-40-round-precision-machine-pins-/181076114852?pt=LH_DefaultDomain_0&hash=item2a28fa3da4
I went looking for some S08 to DIP and purchased some 20 pin devices that I cut in half with a hacksaw. Seemed less costly and worked fine. I added by-pass caps with surface mount devices.
Advantages of the machine variants are smaller PCB holes, and they can plug directly into Machine Pin IC Sockets, and normal Dual Wipe IC sockets
Disadvantage is they are rather easy to snap off...
I've found you can insert the standard sq pins into the much cheaper Dual Wipe (AMP) socket, on a 'one way' basis.
(ie once you use the Sq pins, a normal IC is too loose), but that is managed by using a 'permanent' Dual Wipe socket as a transition element, so you have [SqPins -> DualWipe] -> target PCB socket
That then gives you the strength of sq pins, and the cheap/easy replacement of a Dual wipe socket.
https://www.sparkfun.com/products/117
Note that the pins are different diameter on the two sides--0.018" on one side and 0.025" on the other. Machined pin sockets can accept a range from about 0.015" to 0.025", but breadboards prefer the larger size.
Individual pins are also an option, and Mill-Max makes a huge variety to choose from. They are very expensive until you buy in the thousands, and they are hard to load unless you have a jig or very steady hands. E.g. part numbers 3114-2, 3115-2, 3117-2. It's good for a low profile result.
