TCS3200 - Color Sensor - Student Project (French)
Hello,
First of all, I would like to apologize for my bad english, indeed, I'm a French Student of only 16 years old. I came here to ask you some questions about the color sensor "TCS3200" (this one). We bought it a few weeks ago, and we still don't know how it works.
We can't buy a motherboard, because we've about 200 (thereabouts 260$) for this project.
Our aim is to create a ball sorter. We've 1,6cm (thereabouts 0,6 inch) balls of various color (RGB and Yellow).
To sort them, we've chosen to use a worm wheel with a tray on which we fixed a jack and a suction cup. To control that I use a industrial and progammable automaton (TX07) with a Grafcet Programm.
The problem is actually to detect the color of the ball with the TAOS TCS3200 and to send it on the API (with an electrical flow maybe). Is there somebody who has already make that here ? Or somebody who could guide me ?
Thank you in advance,
Best regards !
PS : If you want some sketch, don't hesitate.
Best regards !
Is there a possibility to weld cables on the pins to get this signal on the API or on a micro-controller (The professor may have one) ?
Thanks at all for your quick answers !
You can use a microcontroller to do this interfacing. The microcontroller need to have several (I think 5) outputs to the TCS3200 to select which color sensor is to be used and one input for the pulse stream that indicates the intensity of the light. These signals need to be logic signals appropriate for the power supply voltage since the sensor can operate using either a 3.3V or 5V supply voltage.
For the microcontroller, I may be really interested, because we may already have one. But to make the connexion between the sensor and the µcontroller, can I weld cables or do I have to buy this cable ?
