Sound Powered BOE Bot?
All right, so Im trying to have a BOE bot that functions by sound, the sensors dont really absorb sound or use it as a power source. Unfortunately, there were no precedent projects on it and so no help there. Any idea guys? I have the BOE bot ready and Bluetooth Module.
Any suggestions??? Please
There have been several robots that use a SayIt module to give voice control to a robot. I've been experimenting with the SayIt using a Propeller.
What kind of sound do you want to sense? Have you looked around for sound sensors?
Technically any robot that uses an ultrasound to navigate "functions by sound".
:thumb: Ty
I sure the Propeller could do this but I think a BS2 could probably do it as well with some external circuilts. Maybe (as Mike suggested) a mic with an amp and RC decay circuit or some other ADC to measure the amp's output?
Once the sound level was determined the CR servos could be sent appropriately.
With two mics and amps, it may be possible to have the bot move toward or away from the sound.
A chip like this may make the task easier.
