$49 Autonomous Quadrotor Camera? Really? — Parallax Forums
ercoerco Posts: 20,263
edited 2013-03-05 10:59 in General Discussion
Autonomous, voice control, follows you around, transmits streaming video... all for $49? Hmmm. Erco has doubts...
http://www.designnews.com/author.asp?section_id=1386&doc_id=259721
    edited 2013-03-05 09:34
    ..but for $49 when/if it's ever licensed or sold by AI or IA or whoever.....it's worth that just for the hack factor.
    Weddings should be fun with everybody's mecam vying for space. You'll need a way to ENFORCE restricted airspace!
    edited 2013-03-05 09:45
    AI, acually has very cool products. They were one of the original companies that made me want to start doing embedded projects! They have a tablet based on the beagle bone, which can turn in to a netbook with a keyboard add on. Very neat stuff, usually AI's gear is a bit pricey, but If there aunouncing this it probably works fairly well and isn't vapor.
    edited 2013-03-05 10:16
    Let's see if I understand this correctly. It accepts voice commands, so it must have a microphone. But where? On the same platform as four screaming motor-driven propellers?
    edited 2013-03-05 10:20
    Silly Phil. Surely they've seperately perfected an adaptive, embedded, hidef, hires, bluetooth dolby quad noise cancelling algorithm. There's an app for that!
  • blittledblittled Posts: 695
    edited 2013-03-05 10:22
    Is the voice recognition also tuned into your vocal pattern? If not a complete stranger can walk by take verbal control and get all sorts of embarrassing video of you!
    edited 2013-03-05 10:24
    Oh, and I forgot disruptive. :)
    That seems to be the buzzword de jour for crowdfunding, anyway.
    Back when I was in gradeschool, disruptive was a BAD thing. My, how times have changed.
    edited 2013-03-05 10:27
    I imagine the voice commands would needed to spoken into the smart phone.
    I tried adding an ultrasound to my $100 HobbyKing quadcopter, it worked fine as long as the motors were off. Apparently those little motors output some high frequency noise. I haven't mentioned much about my quadcopter ultrasound experiments since it would give erco yet another chance to say "I told you so".
    I just don't see a microphone on a quadcopter being of much use except to record the sounds the quadcopter is making.
    edited 2013-03-05 10:33
    A phone makes sense for a microphone. Just don't make it go too high for aerial shots or the Air Force may mistake it for a drone and shoot it down :).
  • NWCCTVNWCCTV Posts: 3,629
    If it realy works then why do they use an animated video to showcase it? I would buy one just to play around with but they are not available yet.
