SPIN code problem reading MCP3202 — Parallax Forums
MJHanaganMJHanagan Posts: 189
edited 2013-03-07 12:21 in Propeller 1
Wow, I am banging my head against the wall looking for the error in my SPIN code. I am trying to write the basic code to communicate with an MCP3202 and while the hardware setup works fine with downloaded MCP32xx objects I cannot seem to get my simple code to work. I have compared my code with Harprit's simple MCP3202 SPIN code and I cannot identify where I'm going wrong.
My hardware setup has a constant 2.505 V signal on channel 0 and a small AC voltage offset by +0.2V on channel 1. The "ZCPin" changes state each time the AC voltage passes through zero (excluding the +0.2 VDC offset). When I run any of the downloaded MCP32xx objects I get the correct measurements but when I run my code I get output as shown below the code.
Can anyone spot my error?
CON
    _clkmode = xtal1 + pll16x
    _xinfreq = 5_000_000
    ZCPin = 11      ' Zero cross signal input pin
    TransformerPin = 18  ' Output pin which turns on the ZC TRIAC relay sending 120 VAC to the power transformer.
    ADCCS = 26    'MCP3202 Chip Select pin.
    ADCClk = 25   'MCP3202 serial clock pin
    ADCDIO = 24   'MCP3202 Data in and data out pin
    High = 1
    Low = 0
    Output = 1
    Input = 0
OBJ
        pst     : "Parallax Serial Terminal"
Var
  long ADCData[ 100 ], ADCtime, nChan
Pub Main |  i, j, k
    pst.Start( 115_200 )             'Start the serial terminal interface running at a baud rate of 115,200
    waitcnt (cnt + clkfreq/2 )
    pst.Beep
    pst.clear
    pst.str(string(pst#NL,"Operating clock frequency: "))
    pst.dec( clkfreq/1000000 )
    pst.str(string(" MHz"))
    dira[ ZCPin ] := Input  ' Set ZC pin as input
    DIRA[ TransformerPin ] := Output   ' Set transformer pin as output.
    outa[ TransformerPin ] := High   ' Turn on power to transformer.
    waitcnt (cnt + clkfreq )
    pst.str(string(pst#NL,pst#NL,"Power is now on."))
   pst.Beep
   nChan := 0
      j := ADCRead( nChan )
      pst.str(string(pst#NL, pst#NL,"ADCReads: "))
      pst.dec( j )
      pst.str( string(" on channel: "))
      pst.dec( nChan )
      pst.str( string(" Single read CNT: "))
      pst.dec( ADCtime )
      pst.str(string(" Data follows:", pst#NL))
      IF j > 0
        i := 0
        REPEAT j
          pst.str(string(pst#NL,"n="))
          pst.dec( i )
          pst.str(string("  "))
          pst.dec( ADCData[i] )
          pst.str(string(", %"))
          pst.bin( ADCData[i++], 16 )
   nChan := 1
      pst.dec( j )
      pst.dec( nChan )
      pst.dec( ADCtime )
      IF j > 0
        i := 0
        REPEAT j
          pst.dec( i )
  outa[TransformerPin] := Low 'Turn off main track transformer.
   pst.str(string(pst#NL,"  Transformer power is now off."))
   pst.Beep
   pst.str(string(pst#NL, pst#NL, "Program run terminated, good-bye."))
   pst.Beep
PUB ADCRead( Chan ) | i, j, k, StartCNT, EndCNT
    DIRA[ ADCClk ] := Output    ' Set clock pin for output
    OUTA[ ADCClk ] := Low       ' Set clock pin low
    DIRA[ ADCCS ] := Output      ' Set chip select pin for output
    OUTA[ ADCCS ] := High        ' Set chip select pin high
    WAITPEQ( %0, |<ZCPin, 0 )    'Wait for ZC pin to go low
    j := 0
    WAITPEQ( |<ZCPin, |<ZCPin, 0 )    ' Wait for ZC pin to go high to initiate measurement loop
REPEAT UNTIL INA[ ZCPin ] == 0  ' Make repeated ADC measurements until the zero cross pin goes low
    StartCNT := CNT
    DIRA[ ADCDIO ] := Output    ' Set DIO pin as output
    OUTA[ ADCDIO ] := Low        ' Set data pin low
    OUTA[ ADCCS ] := Low        ' Set chip select pin low to initiate ADC communication/conversion process
    OUTA[ ADCDIO ] := High      ' Set DIO pin high (start bit)
    OUTA[ ADCClk ] := High      ' Set clock pin high.  The MCP3202 reads the data on the rising edge of the clock.
    OUTA[ ADCDIO ] := High      ' Set DIO pin high for single ended measurements (which it is already!)
    OUTA[ ADCDIO ] := Chan      ' Set DIO pin low for Ch0 or high for Ch1
                                ' The MCP3202 begins the sampling of the voltage at this moment.
    OUTA[ ADCDIO ] := High      ' Set DIO pin high for MSB data mode (MCP3202 send result MSB first)
                                ' The MCP3202 ends the sampling of the voltage at this moment.
    DIRA[ ADCDIO ] := Input      ' Set DIO pin for input
    OUTA[ ADCClk ] := Low        ' The MCP3202 outputs a low null bit on the falling edge of the clock pin.
    i := %0       ' Clear the result variable
    REPEAT 12               ' Read the the subsequent 12 data bits (MSB to LSB order)
      OUTA[ ADCClk ] := Low ' Set clock pin low. The MCP3202 outputs the next data bit on the falling edge of the clock pin.
      i <<= 1               ' Shift already read data bits left one position to make room for the next data bit.
      i := i + INA[ ADCDIO ]' Add the read data bit into the LSB position
      OUTA[ ADCClk ] := High' Set clock pin high
    ADCData[ j++ ] := i     ' Copy the ADC data into the data storage array
    OUTA[ ADCCS ] := High   ' Set chip select pin high to end communications.
    EndCNT := CNT
    ADCtime := EndCNT - StartCNT
RETURN j-1       ' Return the number of measurements made.
Typical results when running the code above:
Operating clock frequency: 80 MHz
Power is now on.
ADCReads: 12 on channel: 0 Single read CNT: 49424 Data follows:
n=0  2, %0000000000000010
n=1  7, %0000000000000111
n=2  2, %0000000000000010
n=3  0, %0000000000000000
n=4  0, %0000000000000000
n=5  0, %0000000000000000
n=6  4090, %0000111111111010
n=7  4095, %0000111111111111
n=8  4095, %0000111111111111
n=9  0, %0000000000000000
n=10  5, %0000000000000101
n=11  5, %0000000000000101
ADCReads: 12 on channel: 1 Single read CNT: 49424 Data follows:
n=0  264, %0000000100001000
n=1  0, %0000000000000000
n=2  0, %0000000000000000
n=6  0, %0000000000000000
n=7  0, %0000000000000000
n=8  0, %0000000000000000
n=10  0, %0000000000000000
n=11  0, %0000000000000000
  • Mark_TMark_T Posts: 1,981
    edited 2013-03-03 16:13
    I don't understand your indentation with the REPEAT UNTIL
  • MJHanaganMJHanagan Posts: 189
    edited 2013-03-03 16:50
    Mark_T wrote: »
    I am trying to measure the voltage as many times as possible during the positive phase of the AC voltage. I wait for the voltage to pass through zero before starting then measure as many times as possible until it passes through zero again. In SPIN I only get 10-15 measurements depending on the lines of code. Once I get the SPIN working I want to go into PASM so I can get many more samples measured (the ultimate goal being ~100+ samples per 60 Hz line cycle of V and I data so I can calculate the real power being dissipated).
  • JLockeJLocke Posts: 354
    edited 2013-03-04 00:39
    MJHanagan wrote: »
        j := 0
        StartCNT := CNT
    I believe the reference was to the REPEAT being aligned with the left margin (same as your function declaration). Is this intentional; does your code indent like that, or was that an artifact of posting your code to the forum?
    edited 2013-03-06 03:44
    JLocke wrote: »
    Yes, the REPEAT is supposed to be at theeftmost position. All the ADC measurement is repeated until the next zero crossing event. In SPIN I get roughly 10 to 15 measurements in this REPEAT loop. The error is somewhere below this line.
  • Mike GMike G Posts: 2,702
    edited 2013-03-06 06:11
    Are you sure the SPIN code within the REPEAT UNTIL INA[ ZCPin ] == 0 block is always executing within the positive swing of the signal? I believe this is right, ~0.8 * (2 * 1/freq).
    I would spin up another COG to process zero crossing state.
    edited 2013-03-07 07:35
    Mike G wrote: »
    Yes, the ZCPin is high when the AC voltage is high. The SPIN code within the REPEAT loop runs 10-15X during each positive phase of the AC voltage. The problem I'm having has something to do with the communication code to the MCP3202. When I substitute code from one of the downloaded objects I get the correct data from the MCP3202 but when I substitute my code it get back garbage from the MCP3202.
    I could be wrong about this, and was.........
    FF
    Ehhhh,never mind, just saw the dira for input.
