Trying to save IO pins using mcp23017 i2c GPIO expander.
Ok so I have 5 of these sonar modules I want to hook up. They each have 2 data pins, a trigger and an echo. Once you pulse trigger line the module sends out an ultrasonic noise which is then read by measuring the amount of time the echo pin is hi. These are all 5v sonar modules, so you need resistors on the trigger and echo line when connecting directly to a prop. Some other forum members have come up with solutions for cutting the pins by using a pull down and some diodes. While this method works it isnt exactly what im looking for,
I have a bunch of mcp23017 and 23018 chips around they are 16 post gpio expanders, the 23018 can even act as a 5v tolerant buffer.I figured id use one of these chips and then have 6 extra I/O left! There is no obex object, but Johnny Mac has written some code and posted it on the forums, found here
http://forums.parallax.com/showthread.php/107967-mcp23017-(i2c)-example-code
from what I can tell this is just a very simple demo showing how to talk to the chip, im not even sure how you would use it to address single pins, not just ports. That is neither here nor there though. Looking through this code it seems like you can only read and write pits to these gpio's. So does this mean there is no way to actually measure pulse times on these pins, making it a bad choice for these sonars and things that use pulsing as a protocol?
Best speed is probably a 400KHz clock, so that's roughly 40K bytes of information per second. With overhead figured in, that's about 13K bytes per second for writing and 10K bytes per second reading.
I would suggest using a 74HC165 for reading the outputs of the sensors and a 74HC595 for writing the trigger pulses. These are 8-bit shift registers. You can't address individual pins, but these are cheap and you can let the software handle writing the whole 8-bits to change just one trigger. Similarly, the software can handle sorting out which sensor has an echo and for how long.
Being there so slow what are some common applications for these? Reading buttons, flipping LEDs?
You got it. These chips are used for more general I/O, not for more specialized applications like sonar that require precise timing.
In this application timing is paramount!
I suspect you don't want these extra chips in the way of making these fast readings.
You need to have the Prop generate these signals directly through level translators.
Ok, the other chips can be used for slower signals without unduly using up to many Prop pins.
Duane J
You might consider writing a specialty object (in PASM) that will provide your trigger output via the '595 and get your echo timing via a '165. By adding a resistor in the mix you can connect with both using only four IO pins; this would let you control up to eight sonars modules.
http://ww1.microchip.com/downloads/en/DeviceDoc/21952b.pdf
Question, are the 8 sonar units pulsed sequentially, i.e., 1 at a time?
Duane J
Depending on the required sampling rate, maybe the MCP23017/18´s two programmable interrupts for their PORTA and PORTB could be what you were searching for.
In case you have a very time critical application, making use of the props builtin counter functionality for pulse width counting is an option as well as having an external counter or ADC that does the pulse width quantizing for the Prop.
They support up to 1,7MHz I²C operation, but i have not found an OBEX Object fast enough for that yet, tough i haven´t tried them all.
wbr
As far as using the i2c expander this just isnt a good idea at all. You would have to keep reading the port, then create a loop that looks at the indavidual bit echo is attached too and count how long it stays at 1. Im sure between the i2c speed and the code monitoring the bit the timing wont be accurate at all.
I have thought about using a 74lvc244 to do the level shifiting and just jumping echo and trigger togather, but if im going to go through all that may as well just throw in an AVR to read sensor and send the values to the prop via uart or spi.
Or have a look at the ΣΔ-ADC examples in the Appnote to make use of I²C ADC ICs using your echo signal as input to an ADC.
However it depends on what makes sense to you.
wbr
P.S.: i saw i slipped the point that you were talking about polling those inputs via serial data. Any idea how fast you´ll need to poll? You´ve got to make a choice anyway what to do, add more external hardware to unburden tasks from the Propeller and spare I/Os or just wire the time critical I/O directly.
