Very basic question - how to use Boebot without cable attached?
This might be a very simple question so please bear with me....:)
I have my Boebot all up and running but can't seem to figure out how to let it run without the USB cable attached. I have the Serial model. For instance when I am coming to do the ten second forward programme it is not possible as the cable won't stretch. Is there something I am missing???
' {$STAMP BS2}
' {$PBASIC 2.5}
END
This way, the next time you power up the robot to start working with it or if you are changing circuits, it will not suddenly start running a program that you may not be expecting.
I've had the same experience and broke an acrylic bot when it happened. I was using an h bridge at the time so the middle switch didn't help. But otherwise it is a good safety protocol.
