Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Grounding to VSS — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
Grounding to VSS
Tyler Meek
21
2013-02-24 12:16
edited 2013-02-24 17:14
in
BASIC Stamp
Is it safe to ground 12v that is being supplied to a stepper motor via a L293 to VSS on a Board of Education? I have attached the IC with labels
L293 CAD.pdf
94.7K
tonyp12
1,951
2013-02-24 13:01
edited 2013-02-24 13:01
For the control signal to work, the L293's gnd and basic stamp gnd need to be connected (thin connection is better)
673 x 446
16K
15.6K
shimniok
177
2013-02-24 13:41
edited 2013-02-24 13:41
If it helps, you aren't really grounding 12V, you're connecting grounds.
If you have a circuit that operates at 12V, another at 5V, and one at 3.3V, their ground potential should all be the same: 0V.
Grounding a 12V supply would make the magic smoke escape.
Tyler Meek
21
2013-02-24 17:14
OK thanks guys
Sign In
Register
to comment.
