Grounding to VSS
Is it safe to ground 12v that is being supplied to a stepper motor via a L293 to VSS on a Board of Education? I have attached the IC with labels
pdf
95K
If you have a circuit that operates at 12V, another at 5V, and one at 3.3V, their ground potential should all be the same: 0V.
Grounding a 12V supply would make the magic smoke escape.
