Propeller Eduacation Kit Labs:Fundamentals (Problem)
Hey guys, I'm new to the propeller and I have just started the lab kit, currently on lab 3 setting up at testing the propeller. I've checked all of my wiring many times and it all seems to be correct, and I'm measuring all of the correct DC voltages across everything, however I'm getting 6.5V AC across all of the power/ground connections. In the lab manual it says that the AC voltage should be in the mV and if it's any higher then I should consult page 44(troubleshooting - 11)
My capacitors are connected in the correct sockets, the top one measuring 5V DC (10V AC) and the bottom one measuring 3.3V DC (6.5V AC)
Like I said, all of my DC voltages are still correct, from G3 to any black is only 5V DC, from G1 to any black is 9V DC and any red to any black on the rest of the board is 3.3V DC, but i still have that 6.5V AC every where. Any Help would be much appreciated!
Do I understand correctly, that your 5V and 3.3V supplies read correct in the DC mode of your voltmeter but the same supplies read 6.5V when the voltmeter is in AC mode?
What kind of readings do you get if you use your voltmeter on a battery (in both DC and AC modes)?
My power supply is the 9V battery and the usb conection is supplying some as well i would assume. And the 6.5 or 6.6V AC is anywhere on the board from power to ground. All of my power connections (Red wires) are coming off of the 3.3V voltage regulator. From the 5V regulator plugged in next to it to ground i am getting 10V AC
So i might just be worrying about nothing, but in the lab manual it says that the AC voltage should be around 50mV...
I think you're good to go.
The AC should only be a problem if you're using a wall-wart type power supply. A 9V battery doesn't have an AC component.
You may want to upgrade your 9V battery to some NiMH AA cells to save on money. You'll also want to use a different battery (or other power supply) if you use a servo. 9V batteries and servos are a problem waiting to happen (the 9V doesn't provide enough current for many servos and will cause the Propeller to reset).
Just started playing with this thing and didn't want to burn anything the first day and have to get a new one haha.
Did you try testing a free-standing battery with your multimeter on its AC setting just to see what it reads? It's very possible that the bad 6 volt AC reading is simply a reading within the cheap multimeter's margin of error. That is, 6 volts/200 volt range is about a 3% error, or 97% accuracy in that given range. I suppose it could also be an artifact of your multimeter's internal battery getting weak, so if you haven't changed the battery in a while, you might see if that gives better results.
Actually, I recognize that meter. It's a $5.00 Harbor Freight multimeter. I've got several of them. They come with some rather poor Chinese batteries (at least mine did) I'll second this comment to change the battery and see if your results change.
Jeff
Ive never used a PE-Kit but when I started I basically got all the parts from parallax to bread board my first propeller circuit. I used the 3.3v regulator in the store along with the suggested filtering caps and it filters out the wal warts filter fairly well. I think the three volt regulators use a .1uf and 10uf cap, so if thats what the PE kit uses it should be fine.
Good Luck,
FF
[QUOTE=dmoore;1165
861]
My power supply is the 9V battery and the usb conection is supplying some as well i would assume. And the 6.5 or 6.6V AC is anywhere on the board from power to ground. All of my power connections (Red wires) are coming off of the 3.3V voltage regulator. From the 5V regulator plugged in next to it to ground i am getting 10V AC[/QUOTE]
