Memory add-on for the Propeller QuickStart useful for large C programs - Page 2 — Parallax Forums
2»
  • jazzedjazzed Posts: 11,803
    edited 2013-02-20 16:45
    Hi David,
    Of the 3 options shown I like the one with the SDCard added the best.
    Having clean chip select is important to me. If necessary we can use a lock to protect the clock.
    Also it may be useful to have pull-ups on Data2/3 for the hold/write protect disable.
    Another advantage of having the SDCard added is for sales to bread-board or other users.
    It becomes a general solution.
    --Steve
  • RaymanRayman Posts: 16,271
    edited 2013-02-20 18:21
    The one problem I see is that fsrw (last time I checked) doesn't always leave the SD MISO pin in the tristate condition... So, you'd have a pin contention problem. I've heard that modifying fsrw to send extra clocks can fix that though. Still, I think I like your first option best.
    If you're not doing a full 8-bit bus on P0..P7, I don't think you gain a whole lot (in general) on having a 4 bit bus on P0..P3.
    Maybe you can move the flash CS to P1 and clock to P2? Wait... That doesn't work...
    It's late here, but I don't immediately see how to make it work...
    Maybe I'd drop back to just one SPI SRAM so the clock can be on the 4 bit bus somewhere...
    Another option is just use SPI flash and non-volatile SPI sram and make life simple...
    Or, maybe make so it can be SQI flash with no SRAM or SPI flash and SRAM...
    edited 2013-02-21 14:06
    Why can't the SDCard driver be fixed? I don't recall it being an issue with Propeller-GCC.
    edited 2013-02-22 06:07
    Even if you could fix fsrw, it might still be a challenge because it does background caching. Doesn't that make it hard to know when the pins are free?
  • David CarrierDavid Carrier Posts: 294
    edited 2013-02-22 19:25
    I switched the battery socket out with a two-pin socket. I wasn't planning on including a battery to keep costs down, but including the socket without the battery would probably seem a little unkind.
    I added the microSD card socket using the second pinout I posted, connected as another SPI device with every device having a dedicated Chip Select pin. I have attached a copy of the schematic and layout. It should work in the Human Interface Board, a breadboard, or with a simple modification, soldered into a Propeller Proto Board.
    Does anyone see anything that should change, or is it ready for a prototype run?
    I might modify the board to support the flash in a 16-pin SOIC package, because it tends to be cheaper than the 8-pin package for the same die.
    — David Carrier
    Parallax Inc.
    edited 2013-04-04 16:45
    I have a few prototypes built up with this pinout:
    Propeller
    Flash
    SRAM
    SD Card
    P0
    Data 0
    Data 0
    Data In
    P1
    Data 1
    Data 1
    Data Out
    P2
    Data 2
    Data 2
    P3
    Data 3
    Data 3
    P4
    Clock
    Clock
    Clock
    P5
    Chip Select
    P6
    Chip Select
    P7
    Chip Select
    I also have DAT1 and DAT2 from the microSD card each connected to a 1-pin unpopulated socket on either side of the socket itself. (See images at http://forums.parallax.com/showthread.php/147152) I realized that when the microSD card is in use, P2 and P3 aren't doing anything, so I could connect DAT1 and DAT2 to them. I also noticed DAT3 is shared with the Chip Select pin, and DAT0 is shared with the Data Out pin, so I can swap the microSD Chip Select pin with the shared clock pin, and have DAT0 through DAT1 in sequential order. like this:
    Propeller
    Flash
    SRAM
    SD Card
    P0
    Data 0
    Data 0
    Data In / Command
    P1
    Data 1
    Data 1
    Data Out / DAT0
    P2
    Data 2
    Data 2
    DAT1
    P3
    Data 3
    Data 3
    DAT2
    P4
    Chip Select / DAT3
    P5
    Chip Select
    P6
    Chip Select
    P7
    Clock
    Clock
    Clock
    No one has written Propeller drivers for 4-bit mode, as it is somewhat difficult and complex. (See the Latest Simplified Specifications.) In fact, the separate CRC for each data line would make it impractically slow on a lesser microcontroller, but the Propeller could assign a cog to each data line and perform the CRCs in parallel. Anyway, if someone gets around to implementing it, it would be a resource hog, but it could approach the speeds of quad-SPI flash. I would like the Propeller Memory Card to support 4-bit SD mode, should someone write the driver, and this would allow it to happen without soldering and without added costs or drawbacks.
    — David Carrier
    Parallax Inc.
    Edit: I'm also going to add 100 k ohm pull-up resistors to the !CS pins on the quad-SPI devices to ensure the devices are disabled during start-up and when the select lines are otherwise uninitialized.
    edited 2013-04-04 17:28
    4 cogs is a very interesting idea... I might have to try that on SQI flash or sram...
