cognew is NOT!
Ok, so I have an object that calls another and the both function correctly. When I put the second in a new cog it doesent. The hardware is a Demo board'. Leds are to trace where the code gets to. So where does the train come off the track?
CON
_clkmode = xtal1 + pll16x ' use crystal x 16
_xinfreq = 5_000_000
CS = 16 ''CS: Clear Screen
CE = 11 ''CE: Clear to End of line
CB = 12 ''CB: Clear lines Below
HM = 1 ''HM: HoMe cursor
PC = 2 ''PC: Position Cursor in x,y
PX = 14 ''PX: Position cursor in X
PY = 15 ''PY: Position cursor in Y
NL = 13 ''NL: New Line
LF = 10 ''LF: Line Feed
ML = 3 ''ML: Move cursor Left
MR = 4 ''MR: Move cursor Right
MU = 5 ''MU: Move cursor Up
MD = 6 ''MD: Move cursor Down
TB = 9 ''TB: TaB
BS = 8 ''BS: BackSpace
BP = 7 ''BP: BeeP speaker
rainpin = 7
Var
long Stack1[50]
OBJ
debug : "Parallax Serial Terminal"
rain : "raingage021513a"
delay : "timing"
num : "simple_numbers"
Pub Main | tmp
debug.start(115200)
'cognew (testpulse,@stack1)
tmp:=rain.Start(rainpin)
ifnot tmp >0
debug.char(NL)
debug.str(string("oops"))
debug.char(HM)
debug.str(string( " Bucket Tips "))
repeat
tmp := rain.rainamt
debug.CHAR(PX)
debug.CHAR(14)
'debug.CHAR("%")
debug.dec(tmp)
Pub testpulse
outa [7] ~~
dira [7] ~~
repeat
outa[7]~
delay.pause1ms(1)
outa [7] ~~
delay.pause1ms(1000)
The obj with the cognew
Con
fallingedge = %01110 << 26
risingedge = %01010 << 26
calfact = 2111
VAR
long tipscount, cntrpin, testval, cntrpinmask,cog,rainstack[10]
OBJ
delay : "timing"
Pub Start (datapin)
Stop
cog := cognew(getrain (datapin),@rainstack)+1
outa[18]~~
dira[18]~~
delay.pause1ms(500)
outa{18}~
result := cog
Pub getrain(datapin)|cntrpin_
outa [16] ~~
dira [16.17] ~~
delay.pause1ms(1000) ' wait one second
outa [16] ~
cntrpin_ := datapin
cntrpinmask := |< cntrpin_
dira[cntrpinmask] ~
ctra:= fallingedge + cntrpin
frqa := calfact
phsa := 0
PUB Stop
if cog > -1
cogstop(cog -1) 'Stop previously launched cog
Pub rainamt : amount
outa[17]~~
delay.pause1ms(250)
outa[17]~
amount := phsa
return amount
Pub resetrainamt
phsa := 0
Jim
Do you know the timing-object? In general there should be no problem in using the same object in different COGs at exactly the same time! That's one benefit of objects and each object causing trouble in this usecase either needs to have a good reason and proper ducumentation of this exception or I would call it a bad object-design!
@RS_Jim:
kuroneko already explained what is wrong with this object (it immediately stops running which also stops the counter), but there is another bug which might survive for years until it causes trouble! You don't reset the cog-variable in the stop-function and you check for the wrong range!
Pub Start (datapin) Stop cog := cognew(getrain (datapin),@rainstack)+1 ...cognew returns values from 0-7 if a COG has been started and -1 if no COG has been started. Because of the + 1 the value in cog has a range from 0 to 8 (0=no COG started, 1-8=COGID)
Now compare this with your stop-function:
PUB Stop if cog > -1 cogstop(cog -1)It should be "if cog>0" or even shorter "if cog"
And you should set the variable cog to 0 after doing the cogstop! Otherwise calling stop might stop other COGs which is not intended!
Actually your code tries to stop COG 7, as the variable cog is initialized with 0 when starting up the propeller. 0 > -1 is true and 0 - 1 = -1 = %11111111_11111111_11111111_11111111 which is used by cogstop just like a 7 = %111.
Never got from start to certain so I moved it to just after start to see if that would work. The object does work, just not with the cognew.
Jim
Part of the goal here is to learn how to get multiple cogs running and get predictable results from each. Some of the cogs will be pasm and I am confident a can read the results and report them back from there, but this simple task did not seem to merit asm.
Jim
If you want to share counter data from different cogs have them run some loop which occasionally samples and (optionally) resets phsx then stores it in a central hub location.
