cognew is NOT! — Parallax Forums
cognew is NOT!
RS_JimRS_Jim Posts: 1,775
edited 2013-02-16 17:02 in Propeller 1
Ok, so I have an object that calls another and the both function correctly. When I put the second in a new cog it doesent. The hardware is a Demo board'. Leds are to trace where the code gets to. So where does the train come off the track?
CON
  _clkmode      = xtal1 + pll16x                        ' use crystal x 16
  _xinfreq      = 5_000_000
  CS = 16  ''CS: Clear Screen
  CE = 11  ''CE: Clear to End of line
  CB = 12  ''CB: Clear lines Below
  HM =  1  ''HM: HoMe cursor
  PC =  2  ''PC: Position Cursor in x,y
  PX = 14  ''PX: Position cursor in X
  PY = 15  ''PY: Position cursor in Y
  NL = 13  ''NL: New Line
  LF = 10  ''LF: Line Feed
  ML =  3  ''ML: Move cursor Left
  MR =  4  ''MR: Move cursor Right
  MU =  5  ''MU: Move cursor Up
  MD =  6  ''MD: Move cursor Down
  TB =  9  ''TB: TaB
  BS =  8  ''BS: BackSpace
  BP =  7  ''BP: BeeP speaker
  rainpin = 7
Var
  long Stack1[50]
OBJ
  debug : "Parallax Serial Terminal"
  rain  : "raingage021513a"
  delay : "timing"
  num   : "simple_numbers"
Pub Main | tmp
  debug.start(115200)
  'cognew (testpulse,@stack1)
  tmp:=rain.Start(rainpin)
  ifnot  tmp >0
    debug.char(NL)
    debug.str(string("oops"))
  debug.char(HM)
  debug.str(string( " Bucket Tips "))
  repeat
    tmp := rain.rainamt
    debug.CHAR(PX)
    debug.CHAR(14)
    'debug.CHAR("%")
    debug.dec(tmp)
Pub testpulse
    outa [7] ~~
    dira [7] ~~
    repeat
      outa[7]~
      delay.pause1ms(1)
      outa [7] ~~
      delay.pause1ms(1000)
The obj with the cognew
Con
  fallingedge = %01110 << 26
  risingedge = %01010 << 26
  calfact = 2111
VAR
   long  tipscount, cntrpin, testval, cntrpinmask,cog,rainstack[10]
OBJ
delay : "timing"
Pub Start (datapin)
    Stop
    cog := cognew(getrain (datapin),@rainstack)+1
    outa[18]~~
    dira[18]~~
    delay.pause1ms(500)
    outa{18}~
    result := cog
Pub getrain(datapin)|cntrpin_
   outa [16] ~~
   dira [16.17] ~~
   delay.pause1ms(1000)                              ' wait one second
   outa [16] ~
   cntrpin_ := datapin
   cntrpinmask := |< cntrpin_
   dira[cntrpinmask] ~
   ctra:= fallingedge  + cntrpin
   frqa := calfact
   phsa  := 0
PUB Stop
if cog > -1
  cogstop(cog -1) 'Stop previously launched cog
Pub rainamt : amount
   outa[17]~~
   delay.pause1ms(250)
   outa[17]~
   amount := phsa
   return amount
Pub resetrainamt
    phsa := 0
Jim
    edited 2013-02-16 06:35
    What do you expect to happen? getrain will eventually exit and therefore shut down the counter. Calling rainamt - OTOH - will return phsa for the calling cog.
    edited 2013-02-16 06:41
    Your stack in the OBJ is marginal in size. I'd make it 20 elements. Another problem might be the use of delay from more than one cog at a time. Why not just use "waitcnt(clkfreq/2+cnt" instead of "delay.pause1ms(500)" and "waitcnt(clkfreq+cnt)" instead of "delay.pause1ms(1000)"?
  • MagIO2MagIO2 Posts: 2,243
    edited 2013-02-16 10:12
    @Mike:
    Do you know the timing-object? In general there should be no problem in using the same object in different COGs at exactly the same time! That's one benefit of objects and each object causing trouble in this usecase either needs to have a good reason and proper ducumentation of this exception or I would call it a bad object-design!
    @RS_Jim:
    kuroneko already explained what is wrong with this object (it immediately stops running which also stops the counter), but there is another bug which might survive for years until it causes trouble! You don't reset the cog-variable in the stop-function and you check for the wrong range!
    Pub Start (datapin)
        Stop
    cognew returns values from 0-7 if a COG has been started and -1 if no COG has been started. Because of the + 1 the value in cog has a range from 0 to 8 (0=no COG started, 1-8=COGID)
    Now compare this with your stop-function:
    PUB Stop
      if cog > -1
        cogstop(cog -1)
    It should be "if cog>0" or even shorter "if cog"
    And you should set the variable cog to 0 after doing the cogstop! Otherwise calling stop might stop other COGs which is not intended!
    Actually your code tries to stop COG 7, as the variable cog is initialized with 0 when starting up the propeller. 0 > -1 is true and 0 - 1 = -1 = %11111111_11111111_11111111_11111111 which is used by cogstop just like a 7 = %111.
  • RS_JimRS_Jim Posts: 1,775
    edited 2013-02-16 11:53
    I put the LEDs into the object to trace where it was going. LEDs 16and 17 never light. I did have getrain at the end but it
    Never got from start to certain so I moved it to just after start to see if that would work. The object does work, just not with the cognew.
    Jim
    edited 2013-02-16 15:52
    RS_Jim wrote: »
    Each cog has its own counter pair. Simply calling the methods from cog N will setup counter AN and return reads for phsaN, OK. Putting the counter setup into a new cog will setup counter AM and still only read from phsaN, NG. Why would you delegate a counter setup into a different cog anyway? Provided you don't use all caller's counters already you might as well stick with calling those methods.
    edited 2013-02-16 16:47
    My goal was to set up counters in more than one cog and access the results from the central caller. Ok, why when I start the counter In Am do i get phsa in An?
    Part of the goal here is to learn how to get multiple cogs running and get predictable results from each. Some of the cogs will be pasm and I am confident a can read the results and report them back from there, but this simple task did not seem to merit asm.
    Jim
    RS_Jim wrote: »
    phsx is a cog register only available in said cog. Other cogs can't access it unless cog M shares it through hub. In your example the primary cog calls method rainamt which accesses phsa. This phsa is the primary cog's phsa (because the method runs in the context of the primary cog) and since this counter isn't used you'll most likely read 0.
    If you want to share counter data from different cogs have them run some loop which occasionally samples and (optionally) resets phsx then stores it in a central hub location.
