Let's chat.. I'm taking Propellerpowered to the streets. Is it time to go C? — Parallax Forums
edited 2013-02-17 11:21 in General Discussion
Propellerpowered phase 1 is pretty much complete.
A shiny, well functioning store with what I think are reasonable prices is in operation and inventory is on the shelves.
It's time for phrase 2.. Actually finding customers to shop at Propellerpowered. ..uh..em.. Building a decent documentation archive to help folks get started with the Propeller.
Let's face it. While Propellerpowered is great and all (at least we think so). The regulars here are comfortable with shopping direct with a lot of the same sources I do, yes, while some of you visit, and a few of you shop. There isn't enough action to keep Propellerpowered open with current traffic levels. I'm hunting for new blood as always.. (says the vampire) and certainly any continued recruiting benefits us all.
So I'm getting ready to overhaul the original Propellerpowered.com domain and convert it to a documentation haven. I have a lot of stuff that has been earmarked for a revision of the Propeller Cookbook, materials that have found their way into current Instructables, and a bunch of getting started guides..
So let's get to the original intent of this...
Spin (who I dearly love) has always been considered a "red headed stepchild" by the mainstream.
He's grown up to become a teenager and has a lot of natural ability, but he doesn't have the maturity of his grandfather, C. Spin is even pretty smart for his age, but he's been having a hard time being taken seriously.
Is it time to bit a fond farewell to Spin and start producing guides, materials, and Instructables in C?
You guys are my peers. Is it time to press forward with something more industry standard in this regard?
Jeff
    edited 2013-02-14 11:14
    There is a risk that C will be a support nightmare. Best to wait until the propGCC guys are out of BETA.
    C implies all the stuff we associate with a linux workstation. That is, there are standard libraries that automagically have everything built in and it just works. Whatever technical knowledge is required is accounted for in the compiler.
    This appears to be fine for something like an arduino model. But in the prop model that are lots of things that are different for example 8 cores, no interrupts, and 32K hub main memory, and 2K cog registers. These are the exact differences that make the prop useful and different from other offerings, and the reason why we need spin in the first place. We have to understand what these differences are, and what they imply, and how to best work with them to our advantage, when using any language or tool set.
    Moving to C does not eliminate the need to understand the uniqueness of the prop. Not understanding makes moving to C even harder, as a bunch of our assumptions are no longer correct.
    By all means take advantage of C, but let the prop GCC guys lead.
    edited 2013-02-14 11:20
    We're near to a threshold on this. As long as the Prop 1 and the Propeller Tools are the official / supported platforms, I think we should stick with Spin. The GCC Prop compiler / SimpleIDE is still in Beta even though it works well. Some sample Prop 2 chips should be available for testing in a few weeks. It's certainly time to build up a collection of documents based on the GCC package and C, so they'll be ready for when Beta testing is done. Since Parallax already has a mass of documents based on Spin, so why not base PropellerPowered.com on the GCC compiler and C. Catalina could also be supported if you want, but the GCC system is where Parallax is going.
    edited 2013-02-14 11:21
    Short answer: Yes
    Long answer: I believe that SPIN is the reason why the Propeller has followers, not users. When discussing the Propeller with customers that are using other microcontrollers, there are two reasons why they won't look at the Prop: an industry standard C IDE (~80%) and comparable cost (~30%). With an industry accepted C IDE, the cost factor will reduce considerably once users learn how to take advantage of the Propeller's features. Although I consider SPIN easy to learn, most of the Engineers I deal with learned C in college and have chosen to lock into it for any solution they design. Need to tap that market with the prop.
    edit: of course do as Mike and Prof_Braino suggest: jump on the GCC train!
  • lardomlardom Posts: 1,659
    edited 2013-02-14 11:25
    The grandfather and the stepchild can join forces. "IBM compatible" machines became the standard but they were also buggy because many companies had trouble meeting the industry standard. The Apple was more reliable. Both C and the Propeller are here to stay.
  • BeanBean Posts: 8,129
    edited 2013-02-14 11:32
    The main problem with not using spin is that almost all the objects in the OBEX are written in spin.
    So you end up re-writing almost everything because you cannot use any of the objects in OBEX.
    Bean
    edited 2013-02-14 11:44
    I think it is a great idea, there arent very many recources out there for the propeller beginner that wants to use C, most people know it most people are comftorable with it. The issue is knowing how to use it on the propeller, how to set register, and work with the hardware. I really think some tutorials that cover the basics, like things that are covered in the PEKit, but geared twords C. I use C on the PC, and avrs all the time, have used C for years but wont use it on the prop yet. This is because I a micro controller newb and all the good info for the prop is demonstrated in SPIN.
    I have a feeling there are a lot of people who dont use the prop because they dont want to learn SPIN, as others have stated, now C is here but there is really no reason for them to use the Prop still because theres no documentation demonstrating C on a propeller.
    The other issue with C on the prop, in my eyes, is theres so much stuff in OBEX, its great, but doesnt work with C this means most drivers will have to be written from scratch... I know this is only problem that can be solved over time, but it will only be solved when regular people can get started with the propeller and C and start writing drivers. Right now C on the prop is only accessible to the GURU type people like jazzed who have years of experince with both C and Low Level micro programming.
    edited 2013-02-14 12:01
    lardom wrote: »
    The multitude of replies have provided a great sounding board! Thanks to all of you!
    @Larry, you might have had the best advice of all.. Do both.. That message is coming through 5-by-5.
    Jeff
  • Cats92Cats92 Posts: 149
    edited 2013-02-14 14:00
    I tried to use PropGC and Simple IDE some months before . Going happily through starting tutorial and exemples.
    But wanting to go further , have a lot of problems with paths and including libraries.
    So i came back to Spin !
    The beta version of GCC and Simple IDE needs a more extended documentation, more exemples and tools in Obex.
    After a promising start the beta version as not shown much progress recently. Is the Propeller II using all the energies ?
    Jean Paul
  • Ken GraceyKen Gracey Posts: 7,416
    edited 2013-02-14 14:41
    I can't write everything I'd like to about PropGCC, but soon this will become an easy question to answer for Jeff. Some of the complexities cited above shall vaporize, hopefully to be forgotten when they are replaced with a C system you can use very well in Propeller. It is effectively designed for the new customer, one who wants more control and capability than they may presently have. I would be very happy to let everybody have a preview, but it's just a bit more than six weeks away.
    The steps we've been through to get to this point have been necessary. We're building a nice C system from the GCC compiler and I am certain our educational customers will be more excited than ever from it's ease of use and very good capability.
    edited 2013-02-14 14:50
    Cats92 wrote: »
    Yes, and no. Some of us are working on Propeller 2 but Steve is hard at work on an updated version of SimpleIDE and a new release of PropGCC for the Propeller 1. I think it's supposed to be available "real soon now". (tm Jerry Pournelle)
    Edit: oops! I see Ken beat me to it. He, of course, speaks with authority. I'm just guessing. :-)
    edited 2013-02-14 14:59
    Bean wrote: »
    It's a shame they can't be compiled to object code, and then called from whatever language the programmer wants to use. Or is this somehow possible already? ...
    -- Gordon
  • NWCCTVNWCCTV Posts: 3,629
    Do I detect that someone was in commo/signal corps in the Military?
    edited 2013-02-14 15:45
    The GCC byte code interpreter isn't compatible with Spin byte codes, and there are significant differences. Many of the most important objects such as video drivers consist of PASM with the Spin code mostly implementing the communications for controlling the PASM cog(s) which do the real work. These will range from needing very little work other than translating simple wrappers from Spin to C, to needing a lot of work to make the control scheme compatible with C data structures.
    edited 2013-02-14 16:04
    So will Spin be gone altogether or will this just be another option? Although I am not up to par with Spin, I do not want to spend a bunch of time learning it if it will be replaced or if there is something better/more powerful to use.
    edited 2013-02-14 16:06
    I have it on good authority that Spin isn't going away.. "He'll" continue to grow and mature.. C on the other hand with come alongside.
    edited 2013-02-14 16:12
    NWCCTV wrote: »
    Spin will remain the key language of course, but expect to see C grow for educational purposes. I can't say if C will be more powerful in the end, but it will provide amazing power very easily. Can't answer any more questions for the time being.
    edited 2013-02-15 04:07
    Braino,
    C implies all the stuff we associate with a linux workstation....This appears to be fine for something like an arduino model.
    I'm confused. Can you guess why?
    I have had this debate with RossH a few times. I'd don't think having a C compiler available implies anything about having all those libraries. People program in C for all kinds of things many times with no standard libraries present at all. Just like you do in Spin. The Arduino is a prime example of this, all be it with a very thin layer of it's own support software.
    edited 2013-02-15 06:07
    Spin objects can be converted to C++ using spin2cpp. I can then be compiled to object code and linked to other C++ files.
    edited 2013-02-15 06:49
    I've used Spin and done several projects in it. While I will likely continue to use it on some projects, I've never really warmed up to it. So far the SimpleIDE and gcc are looking really good and I'm looking forward to a mature C++ compiler on the Propeller chip. I know some people who are C++ skeptics on embedded platforms, but it does work as long as you don't go crazy. The programs you end up with a much more understandable than their vanilla C equivalents.
    edited 2013-02-15 07:08
    Heater. wrote: »
    Braino,
    I can guess, based on our discussion where you said variables and constants are NOT associated with memory locations, that you know much more than I, and love to debate.
    I have had this debate with RossH a few times.... People program in C for all kinds of things many times with no standard libraries present at all.
    I have NOT seen anyone program in C with no standard libraries, this is my disadvantage. You better continue your discussion with RossH, he's a lot smarter than me, maybe he can help you.
    edited 2013-02-15 07:26
    While you certainly can write C code without the standard libraries, these libraries exist because they solve common problems. So why not use them rather than write your own slightly buggy version of them? To fight bloat a good compiler and library implementation are usually modular enough that you'll only pull in what you explicitly call.
    Heater. wrote: »
    Besides the Arduino library, many of the standard libraries are also available for things like trigonometry. They're pretty lean and I've fit a fair amount into 16 kB.
  • jazzedjazzed Posts: 11,803
    edited 2013-02-15 07:39
    A few of us have been working like crazy on SimpleIDE for education's needs. There are good things coming for education users and hobbyists. SimpleIDE has been working fine for a long time, but there are changes coming that make it simpler to use specifically for the education environment with feature enhancements as defined by Parallax. The flavor of the original SimpleIDE will also be preserved and improved. Unfortunately early previews are not allowed yet.
    edited 2013-02-16 09:23
    Braino,
    I was confused because on the one hand you statement suggested C implied all the
    baggage of the standard librarie and was best suited for workstations. On the
    other hand it said "...appears to be fine for an Arduino...". So which is it?
    ASIDE: I don't remember clearly enough to quote myself but I'm sure I did not
    say "variables and constants are NOT associated with memory locations". Rather
    I was taking issue with your statement that a variable was a short hand for a
    memory location. My only small point there is that "memory location" is a
    feature of the hardware design of our computers whereas "variable" is a
    semantic construct of some language definition which can mean whatever the
    language designer chooses. I'm still composing an email reply for you my view
    of that.
    Sure you have, one of the biggest, most complex and wide spread pieces of C code
    in history, the Linux kernel, does not use standard libraries. How can it the
    standard libraries depend on it and it has nothing underneath except hardware.
    There are plenty of examples of standard lib free code in the propgcc package.
    Pretty much all Arduino projects do not use standard libs. It's everywhere.
    edited 2013-02-16 09:30
    Yes, it's time to go C. SPIN is always there too.
    "Propeller Powered" means Propeller first and foremost right? Focus on that, and the languages that get used, tools that appear, all should be there with your value add being to present them in ways people find attractive.
  • SRLMSRLM Posts: 5,045
    edited 2013-02-16 10:07
    Without looking at the other replies, I'll respond to the original question.
    Yes, I think that PropGCC is ready for use, and a better alternative than Spin.
    I've been using PropGCC for about three months now, every day, and it hasn't disappointed. Everything is available, from object oriented programming to real pointers to type checking to a better build system. In addition, it's cross platform and currently supported (as opposed to Spin on Mac/linux).
    One of the cool features about PropGCC is that you can have inline PASM. I remember how difficult it was to learn PASM with Spin when I took up the challenge years ago. I had to spend a bunch of time setting everything up with a new cog and PASD (great tool, but windows only), and then single step through the program. Now, in C++, I can have inline PASM with a prinf at the end. Much easier and faster build and test cycle.
    The main downside is that there is't too much learning material for PropGCC.
    edited 2013-02-16 10:23
    RE: standard libraries
    For my production code, I'm not using any of the standard libraries*. I found that I prefer the flexibility and power of using current objects, converted via spin2cpp.
    *Ok, I do use strlen and strcat...
    I do appreciate the standard libraries, though. I use printf and putc for quick testing of code, where size doesn't matter.
    edited 2013-02-16 10:25
    And one more thing about using C/C++: it allows the programmer to use established design patterns that are tried and true. It seems like with Spin everybody has to learn on their own, and each pattern is a surprise.
  • RDL2004RDL2004 Posts: 2,554
    edited 2013-02-16 12:08
    The main downside is that there isn't too much learning material for PropGCC.
    I'd be willing to bet that there's a few people "working like crazy" on that also.
  • KC_RobKC_Rob Posts: 465
    edited 2013-02-16 13:35
    Based on discussions I've had with people and what I've seen on other forums, I don't think there are really only two objections to the Prop, or that the percentages break down that way. In any case, the biggest gripe with Spin is simply Why? Why another language altogether? Yes, people sometimes nitpick about the specifics of Spin, but when you dig a little you see that it all originates there.
    Despite the drawback of seeming new and foreign (and pointless) to some, Spin is still the best way to get into the Prop and start doing/learning stuff - and perhaps will be for some time. If it were my decision, I'd continue to make Spin the priority (though I would certainly continue to support other tools/languages, and not just GCC either).
    edited 2013-02-16 15:51
    I'm very sure Spin will have equal footing with C.
    SimpleIDE already supports both and seems to be undergoing a lot of unannounced improvements.
