Is this a viable option for a higher current regulated switching supply?
rwgast_logicdesign
Lets say I had a 22v power supply and I wanted to regulate down to 10v or so, but be able to supply 10amps of current. Could one take a chip such as a 555 (I know a 555 is only good to 16v so its supply would have to be regulated too), adjust its duty cycle until it was outputting 10v, then use a mosfet like this one
http://www.ebay.com/itm/IRF530-IR-Power-MOSFET-N-Channel-17A-100V-/180827883096?pt=LH_DefaultDomain_0&hash=item2a1a2e8658
to supply the current demands.
If this would work, does anyone know if there is a chip out there I could use to generate a duty cycle directly from a 22v supply?
That MOSFET is a relatively old one. It may be rated at 17A and 100V, but the on-resistance is 90mOhms. At 10A, that means a drop of about 1V and a power dissipation of 10W. You'll need a good heatsink for that with the TO220 package and that on-resistance is probably best case (to look good in advertising). Without looking at the datasheet carefully, I don't know what a really typical on-resistance would be and under what conditions. Commonly, you need a decent drive voltage for the gate and plenty of drive current to charge up that gate capacitance. There are much better MOSFETs available.
More and more lately projects I would like to do require mosfets, in the 10 to 20 amp range. Do you have a suggestion on a good mosfet that can handel 30 watts or so without a heatsink? I know there are plenty out there, just not sure which ones are quality I guess...
the 34063 is a VERY usefull chip . and with a External Fet and a proper rated Inductor it can handle the current you need ,...
and has Feedback!!!!!!
and Yes it can do Buck, or Boost .,
Peter
have to deal with saturation and non-linearity and iron-losses. With an air-cored inductor you'll have a large and cumbersome device with a lot of
copper! However it might fair better in open-loop control (and its inherent resistance and power-dissipation ability might help with overloads).
Consider switching at 100kHz, with 0.2V and 2A ripple, using synchronous switching buck circuit (2 MOSFETs), you would want 25uH into 250uF,
an air cored 25uH inductor capable of handling 10A with low resistive losses is a large beast, perhaps a toroid taking up a
cubic decimetre or so. More normally seen in long-wave radio transmitters!
Is about 12 Volts close enough?
First thing that came to my mind was to use a PC APX Power supply, the 12 volt rails have lots of muscle. They even have a seperate 12 V cable, 4 or 6 pin, Brown and Black, for plugging into power ravenous graphics cards. Plenty of sites on the web that show how to modify them so that they can be turned on without a PC MOBO. Lots of folks get elaborate and make 'em into bench supplies.
Hal
