Linking two propeller processors together
Hello,
I am curious about linking to propeller processors together, general strategies on passing data and a common clock.
Regards
Jeff Kane
Regards
Jeff Kane
It really depends on what you want to do. A number of us use multiple props connected in projects and they work nicely.
With 3 Propellers, the third might in some cases manage memory, such as SRAM chips.
Cluso has made boards along these lines and many have followed similar designs.
In other cases, without the user-interface... it is just a matter of how many Cogs do you really need for the given project. SPI serial can be used to reach a second, a third, and more Propellers in a master/slave relationship.
Or, if you want parallel data transfers,
Protoboards can be stacked in an arrangement that Humanoido has explored for Propeller 'super-computers'.
