propeller-load ignored bytes? — Parallax Forums
SRLMSRLM Posts: 5,045
edited 2013-02-02 09:11 in Propeller 1
Sometimes when i download a program the propeller-load ignores some bytes:
... <compiler messages>
Ignored 37 bytes.
Propeller Version 1 on /dev/ttyUSB0
Ignored 63 bytes.
Loading main.elf to EEPROM via hub memory
18668 bytes sent
Verifying RAM ... OK
Programming EEPROM ... OK
Verifying EEPROM ... OK
[ Entering terminal mode. Type ESC or Control-C to exit. ]
Sometimes the bytes are ignored, and sometimes they are not. If I immediately re-run the program, it downloads without ignoring bytes:
18668 bytes sent
In both cases it's downloading the same amount (apparently), and it seems to work correctly in both cases. What's happening here?
    edited 2013-02-01 12:06
    SRLM wrote: »
    Ignored 37 bytes.
    Ignored 63 bytes.
    18668 bytes sent
    18668 bytes sent
    Is this on a QuickStart board? The "ignoring bytes" code was added to get around a problem with QuickStart not having a pullup on the RX line. It doesn't mean that bytes from your program are being ignored. It means that garbage during the initial handshake with the ROM loader is being ignored.
  • SRLMSRLM Posts: 5,045
    edited 2013-02-01 12:27
    David Betz wrote: »
    It's on a custom board, but I did use the QuickStart and Eddie schematics as the base for my FTDI circuit, along with the buffer from a PhiPi post:
    Sometimes when I run my program with the -t option, I notice a bit of garbage at the beginning of the terminal output, but then it never reappears. Is this related? And the fix is a pullup on RX?
    1024 x 796 - 67K
    edited 2013-02-01 12:32
    SRLM wrote: »
    Looks like you already have a pullup on RX. Anyway, this is a point of disagreement. Some people think that the pullup should not be necessary and, in fact, it can get in the way of making more general use of P31. This is why the "ignoring bytes" feature was added to propeller-load. I think the Propeller Tool loader does something similar.
    Edit: oops. I suppose I really meant a pullup on TX? I'm not a hardware guy. Sorry for the confusion!
  • jazzedjazzed Posts: 11,803
    I would have called them garbage bytes, but I'd rather not mention garbage (exhale) and propeller in the same breath.
    The pull up needs to be on U12 pin 3.
