Unfamiliar with Ping behavior
I have to reset my Ping when my robot stops moving. I used 'case' to control "BackUp", "RotateLeft" and "Forward" which speeds up the further away the surface is. If I press the reset button the robot will again move forward. It will make maybe a couple of turns it will stop moving forward but I'll still be able to put my hand in front of it and make it back up or turn.
If my code is buggy I'll find the cause. I want to know if changes in the sensitivity of the Ping is normal. BTW, I power my Prop with 6V using AA's.
