Wired up my Chicken Coop with a Spinneret! - Page 2 — Parallax Forums
2»
  • RickInTexasRickInTexas Posts: 124
    edited 2013-01-29 17:36
    Cool, it works now!
    1024 x 734 - 49K
    edited 2013-01-29 17:41
    Cool, it works now!
    500 x 826 - 104K
  • doggiedocdoggiedoc Posts: 2,255
    edited 2013-01-29 17:44
    Thanks! MikeG's new code base seems to be holding up so far! Not one hang so far!
    edited 2013-01-29 18:20
    Solar panels and SLAs or GEL cells....... Sorta green I guess..
    doggiedoc wrote: »
    @skylight - I've got some of the kinks worked out. One problem was brown out issues form current draw on the battery. The WiFi adapter on the spinneret just pulls too much power. I ran a drop cord out to the coop for a quick fix until I can figure out something more permanent. There still seems to be a issue with the spinneret hanging on occasion but I haven't sorted that out yet.
    edited 2013-01-31 18:36
    Fresher look to page now. Thanks Phil for tips.
    [url]Http://208.104.39.5:5000[/url]
  • MoskogMoskog Posts: 556
    edited 2013-09-25 11:45
    doggiedoc wrote: »
    Hi, when you experienced the hang, could you then PING the Spinneret? Reason for asking, it happends once in a while the Spinneret hang but still we get ping response. Not sure whats the reason of the hanging web-server. Did the software-upgrade solve the problem or did you experience more hangs later?
    edited 2013-09-25 13:01
    Hi Moskog -
    I must apologize because at this point I don't recall what was causing the 'hangs'. I can tell you however that the new base code I mentioned above did seem to fix the issue. No problems since then.
    Doc
    edited 2013-09-25 13:20
    Little: Open the coop door now HAL.
    HAL: I'm sorry Little, I can't do that.
