Multiple LED lighting
I want to use 16-18 white LEDs for background lighting on a wall hanger. Can I simply wire all the LEDS in parallel and power them with a 9VDC battyey or is there a better way to do this? The LEDs don't have to do any tricks, just glow. I will use a pot to adjust the brightness then replace the pot with a fixed resistor.
Thanks for reading.
Mike B.
Thanks for reading.
Mike B.
The usual and safer solution is to use have each LED have its own resistor (wired in parallel as you plan). I'd suggest using the pot on one LED to figure out what resistance is needed to obtain the desired brightness/current and then use this same value for each of the other resistors.
Edit: I agree with Martin and kwinn below as long as the voltage drop across the resistor will remains large enough to regulate the current as the voltage of the battery drops over time.
http://led.linear1.org/led.wiz
I would divide the LEDs into strings of LEDs in series that feed into one resistor at the end. The number of LEDs in each string will be dictated by the voltage drop across each LED and the source voltage. You want the voltage after the LEDs but before the resistor to be large enough so the resistor can adequately regulate the current (10mA usually works). If the power supply is not battery (ie wall supply) it is even better because you will not have to design around the voltage changing over time. Make sure the resistor is large enough to handle the power to be dissipated.
If you need more specific info I would need to know the voltage drop of the LED at the planned operating current, voltage source type and voltage.
Nate
