Questions GCC and Viewport
Does anyone know if the viewport product is still being updated??
Is it possible to use viewport with a GCC project? Is there a GCC conduit??
ViewPort works well with Catalina as an IDE/debugger. Supports line-by-line stepping/breakpoint/watch etc. If there's demand I could port that to gcc.
H
I am not very experienced in programming but was trying to figure out how to use viewport with the new GCC compiler now in beta testing. Would I need a new conduit object??
Getting GCC to work with Viewport will require special modifications. That will not happen unless Hanno does it.
As I understand it, by the end of the Propeller 2 GCC porting project, the Parallax SimpleIDE will allow debugging on both Propeller 1 and Propeller 2 without any special requirements beyond building with debug mode enabled.
