Questions GCC and Viewport — Parallax Forums
SteveW719SteveW719 Posts: 40
edited 2013-01-21 13:41 in Propeller 1
Does anyone know if the viewport product is still being updated??
Is it possible to use viewport with a GCC project? Is there a GCC conduit??
  • HannoHanno Posts: 1,130
    edited 2013-01-21 11:44
    Yes, ViewPort is still active. Latest new feature was ability to easily run/load/debug spin/propbasic code over a bluetooth connection.
    ViewPort works well with Catalina as an IDE/debugger. Supports line-by-line stepping/breakpoint/watch etc. If there's demand I could port that to gcc.
    H
  • SteveW719SteveW719 Posts: 40
    edited 2013-01-21 12:23
    Thank you Hanno
    I am not very experienced in programming but was trying to figure out how to use viewport with the new GCC compiler now in beta testing. Would I need a new conduit object??
  • jazzedjazzed Posts: 11,803
    SteveW719 wrote: »
    Getting GCC to work with Viewport will require special modifications. That will not happen unless Hanno does it.
    As I understand it, by the end of the Propeller 2 GCC porting project, the Parallax SimpleIDE will allow debugging on both Propeller 1 and Propeller 2 without any special requirements beyond building with debug mode enabled.
