Long aligned string
Hi all,
Quick question maybe someone can help with. I would like to put a long-aligned string in hub memory with each character taking a byte. In my DAT block, if I do:
If I do:
I see per the manual you can override alignment, but it looks like you can only do that with a smaller type. i.e.
Does anyone have an idea how to do this?
label long "string"I get the string long aligned, but it uses 1 long per character.
If I do:
label byte "string"I get a byte per character, but the string is not long aligned.
label byte long "string"This still aligns to a byte, what I would like to do is something like
label long byte "string"but, this does not seem to be valid syntax
You really should use a byte array to define a string. Why do you need a long aligned character?
I'm pretty sure there are other ways to do this but I don't recall how.
Thanks.
seems to be the same thing as
What I am looking for is for the characters to be bytes but the string itself to be long-aligned (i.e. the first character starts at a memory address divisible by 4)
Looks like Duane's idea worked perfectly. Thanks.
DAT label long byte "string",0I'm a little confused though, what is the difference between
DAT org label byte "string"and simply
both are byte data types...
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ pst : "Parallax Serial Terminal" DAT mystring long byte "string", 0 workspace long byte $0[16] PUB Main pst.Start(115_200) pause(500) DisplayMemory(@mystring, strsize(@mystring), false) workspace := $31323334 '1234 DisplayMemory(@workspace, strsize(@workspace), false) PUB DisplayMemory(addr, len, isHex) | j pst.str(string(13,"-----------------------------------------------------",13)) pst.str(string(13, " ")) repeat j from 0 to $F pst.hex(j, 2) pst.char($20) pst.str(string(13, " ")) repeat j from 0 to $F pst.str(string("-- ")) pst.char(13) repeat j from 0 to len if(j == 0) pst.hex(0, 4) pst.char($20) pst.char($20) if(isHex) pst.hex(byte[addr + j], 2) else pst.char($20) if(byte[addr+j] == 0) pst.char($20) pst.char(byte[addr+j]) pst.char($20) if((j+1) // $10 == 0) pst.char($0D) pst.hex(j+1, 4) pst.char($20) pst.char($20) pst.char(13) pst.char(13) pst.str(string("Start: ")) pst.dec(addr) pst.str(string(" Len: ")) pst.dec(len) pst.str(string(13,"-----------------------------------------------------",13,13)) PRI pause(Duration) waitcnt(((clkfreq / 1_000 * Duration - 3932) #> 381) + cnt) returnMy interpretation of the problem was just to get the first character "s" long aligned. As you say, the other characters (or 3/4 of them) will not be long aligned.
I imagine iammer wants to pass the start of the string to a cog running PASM using the "par" register.
Beau showed another way (IMO better) to long align the first character of a string of bytes.
Yes, I want to pack 4 characters into a long. What I am looking to do is read 4 bytes of a string at a time using a rdlong instruction. To do that I need the first byte of the string to be long aligned, as rdlong can only read from long aligned addresses. Org is used to set a reference point for symbols in cog memory. And it looks like it long-aligns as well since pasm code must be long aligned.
I ended up doing it like Beau's example, since that is a lot cleaner.
Thanks for the note on the endianess. Little endian is what I want.
