Elev-8 reducing vibration
I recently assembled my Elev-8. When I mounted my go pro i realized how much my copter vibrates. Possible cause could be propeller balance is off. I did notice when installing the props it was very difficult to mount them in a way where they didn't slightly wobble. The the bushing that goes in the propeller is only inserted in the bottom and leaves a little play in the hole in the top. Does anyone here have any solutions to reduce vibrations in this craft?
The Vibration that you saw in your video is most likely what is known as the "Jello" affect. There needs to be a small buffer between the camera and the point of contact on the copter where you are mounting your camera to. I like to use some double sided tape, as it serves to reduce the Jello affect, and to also give me a little more adhesion between my copter and my camera!
As for the gap and wobble you mentioned, if you could take a picture of the motors with the issue and post it here so that I can take a look at it, that would be great, as that will give me something to have a look at.
We'll get you back up in the air and flying in no time!
http://www.youtube.com/watch?v=N02NHYrpA0g
Could you take a picture of this? This seems very strange. Did you include he little round inserts inside the propeller?
Post #19 of the ELEV-8 camera thread has a video I made using an ELEV-8. I thought it turned out reasonably well. The same post shows my mounting method (cable ties).
Yes the spacers are in. The spinner and collet is the issue. The collet is mounted directly on the motor shaft and tightened with the spinner nut, both of which should be perfectly vertically aligned. The wobble is in the collet not the prop itself. Here's a video which may show what I'm talking about. I would like to show a video of me manually turning the prop but this is the best I have since I'm out of town.
P.S. I can't wait to upload the full video. Shot on a cold morning after 4 in of fresh wet snow. Kinda cool.
The spinner in your video looks like it wobbles. I wonder if you received a bad batch?
Once you take some photos/video you might want to contact Parallax customer service to see about a replacement.
We've got a lot of snow here in Idaho. Where are you?
Relatively good collets usually mount in a very true manner.
If you completely bottom out the collet, It's very possible that the collet cannot grab the shaft correctly.
I've had out of true running with Router bits and Dremel tool bits.
If I have a collet assembly running out of true, I always loosen and remove the collet.
Clean again with compressed air to be sure there is not a bit of swarf in there to keep the collet from grabbing correctly.
I replace the collet again, making sure to not completely bottom it out.
Then, when I start to tighten the collet, I twist it several times while the collet nut is not completely tight.
This solves my router bit out of true and my Dremel collet out of true issues.
The other thing that I have observed is that occasionally, I do get a bad collet.
That's just my 2 cents worth.
I hope it helps you in some manner.
gg
I believe it was a bad batch. They looked really cheep. some had threads longer than the other, some the collet looked odd. I am going to research some new ones. Regarding the snow, I'm in south central va. We only get snow a couple times a year, so it's always fun when it happens
Have you found a solution? I just finished building my Elev-8 today and when I took it out for the first flight, I had the same issue. I made sure all screws are tight and eventually identified the collets as the problem. If I remove them, arm the copter and give it a bit of throttle, all of the motor shafts seem to be very straight (no wobble). If I touch them while spinning, they feel quite smooth. If I put on the collets and repeat, I feel a lot of vibration in the spinning collet (without prop. I just used the black plastic prop spacer to allow me to tighten the spinner on the collet). I can see the wobble and feel it. I tried lifting the collets slightly to ensure that they are not bottomed out on the shaft, but that did not help. Three of my collets are wobbly, and one is fine. Can you buy replacements without buying a new set of motors? Thanks for the help.
What I did was purchased collets from another manufacturer. You can buy them from any large online hobby shop. Even amazon has them. They are about 3 dollars each from what I remember.. Buy a lot, you will damage them over time.
Thanks. Did that solve your wobble issues?
Yes.
I received my collets and they do not work. They are E-Flite 3mm collets, and the Parallax website lists the motors as having a 3mm shaft. The collets are slightly too small for the shafts and do not go on. Are these actually 3.175mm shafts? Which did you buy? Thanks again.
After a quick look, the only online parts I could find come on a slow boat from the far east. However, you may be able to find something out there.
Thanks for this. Very helpful. I just ordered some new 3.175mm collets that will hopefully work. Parralax should correct the specs on the motor listing from 3mm shaft diameter to 3.175mm shaft diameter. Unfortunately since most of the cost of the 3mm collets I purchased was for shipping, it is not worth it to return them. No big deal, but it would be nice if others could avoid this issue.
Thanks jonbetzfilms! We'll get that corrected on the product page on Tuesday.
