How to digitally record a 10ms pulse then stretch it out into audio in real time? — Parallax Forums
ElectricAyeElectricAye Posts: 4,561
edited 2013-01-21 22:18 in Propeller 1
I'm wondering if the Propeller can do this. Or if it can do this with a few external components such as ADCs or whatnot.
Let's say you are detecting bursts of data, one burst about every 10 seconds. In real time, each burst is about 10 ms long. If a device could digitally record and then immediately play back each burst slowed down by a factor of about 128, then each burst would be in the audio range and become intelligible to the human ear. Slowed down, the audio signals sound like they are around 1KHz to 5KHz.
So in real time, running continuously, the Propeller would have to do something like the following:
1. Perform an ADC of a burst when one occurs.
2.Store the ADC data somewhere.
3.Play back the ADC data into a DAC at a speed about 128x slower.
4.(optional) If a new burst appears before the previous burst is finished playing, then the new burst interrupts the older one.
Is this terribly difficult to do? Any chance it can be done for less than, say, $50???
  • jmgjmg Posts: 15,199
    edited 2013-01-17 20:40
    I'm wondering if the Propeller can do this... If a device could digitally record and then immediately play back each burst slowed down by a factor of about 128, then each burst would be in the audio range and become intelligible to the human ear. Slowed down, the audio signals sound like they are around 1KHz to 5KHz.
    The Prop would need some help. If you want 5Khz you need to sample > 10KHz and that is the /128 playback, so the record side needs to be 1.28MHz - so an external ADC will be needed.
    I take it you have already got a microphone that good ?!
    That could stream into SPI SRAM, or maybe into On Chip Memory, if you want to be more frugal.
    An advantage of on chip memory, is you can play back on one COG, as you record on another.
    A playback DAC at Audio Speeds should be OK.
    edited 2013-01-17 20:57
    You could use a sigma-delta converter and get about 6 bits of precision: 80 MHz / 1.28 MHz = 62.5. Total cost, exclusive of any preamplification, is just a few cents.
    edited 2013-01-17 21:33
    jmg wrote: »
    I take it you have already got a microphone that good ?!.....
    The original burst signals don't come via a microphone pickup - the bursts are just analog signals resulting from an instrument. But by stretching out those signals in real time, the resulting audio signal might allow a person to monitor things and get a feel for what's happening rather than having to stare at a bank of boring ever-changing numbers.
    jmg wrote: »
    ...An advantage of on chip memory, is you can play back on one COG, as you record on another.....
    Interesting! Thank you.
    You could use a sigma-delta converter and get about 6 bits of precision: 80 MHz / 1.28 MHz = 62.5. Total cost, exclusive of any preamplification, is just a few cents...
    Phil, that sounds great. I'm guessing this wouldn't need very high precision - just enough to run a DAC well enough to make some varying tones. When stretched out in time, the resulting audio sounds a little bit like "whistlers" you might hear on some radio frequencies. So do you think a single Prop would be able to run a sigma-delta conversion, somehow store enough of that data (where? how?), and yet still be able to perform a DAC, too? Thanks!
    edited 2013-01-17 21:59
    ...do you think a single Prop would be able to run a sigma-delta conversion, somehow store enough of that data (where? how?), and yet still be able to perform a DAC, too? Thanks!
    If you follow Phil's lead, you can sample at 1.25MHz to ~6 bits, and pack 5 samples into 32 bits, to write at 250000/sec into HUB Memory.
    10ms at 1.25MHz is 12500 samples, but you gain a little bit from 6/8 packing so need 9375 Bytes per 10ms.
    A full memory load would store a tad over 30ms.
    One COG records,and another COG plays-back.
    edited 2013-01-17 22:17
    jmg wrote: »
    Awesome! That's really cool. Thanks for the insight on this. It's fascinating this one chip could do this!
    edited 2013-01-17 22:26
    ElectricAye,
    By chance are you using ultra sonic as your input?
    edited 2013-01-17 22:31
    ElectricAye,
    Hi Beau,
    no, it's actually for a radio monitoring application I was asked about. But it seems to me that developing some sort of signal stretcher like this could have uses in a lot of different applications. It's a lot more fun to listen to signals that sound like something rather than just "kkkkkkctkkk" on a speaker or numbers on a terminal.
    edited 2013-01-17 22:43
    ElectricAye,
    Reason I ask, is because when I worked in prosthetic research and development we submitted a grant proposal for a device to assist the blind.
    Essentially recording the ultrasonic signature out to about 15 feet, and then audibly playing it back at a lower (adjustable) speed. This was about 17 years ago, so most of the device was made with discrete IC's and a few FPGA's and micro controllers.
    So... I would think the Propeller could do something like this in it's sleep with very minimal external component support. ... I think what you must decide on first is the quality of audio your willing to settle with and work backwards from there as far as memory and speed requirements.
    edited 2013-01-17 23:00
    Essentially recording the ultrasonic signature out to about 15 feet, and then audibly playing it back at a lower (adjustable) speed. ....
    Sounds interesting. (No pun intended.) So was it like the audible equivalent of a radar beam sweeping over an area - and the blind person sorta heard the "terrain" in front on them as the beam swept across or something? My only motivation is to provide something audibly interesting to an otherwise boring monitoring process. When you're trying to impress somebody with your tests and the only thing they hear is "kkkkcctttkk", then you tend to get a lot of "Is that all there is?" But if the signals sing a little, and reveal some of their character, I'm hoping it will help impress the unwashed masses of humanity who might otherwise ignore such otherwise earth-shaking test results.
    edited 2013-01-17 23:13
    "So was it like the audible equivalent of a radar beam sweeping over an area" - sort of, however there was no sweeping....
    An ultrasonic sensor just 'looked' straight ahead. Contrary to popular belief there is data (sound reflections) after the first echo. <- most everyone stops there. One of the key devices, popular in radio receivers was an Op-Amp with a reverse log amplification. This key element effectively linearized what would normally be a decaying (proportional to distance) signal from the ultrasonic sensor. Instead, it was more like a cliff at about 15 feet out, but up until then the signal was relatively linear.
    edited 2013-01-17 23:28
    Neat idea but I suspect with only 6 bit resolution and such a low sample rate the resulting audio may not provide much information to the ear.
    To output a 5KHz signal from that incoming 10mS signal would require sampling at 1.28MHz and produce 12800 samples.
    10 bits of resolution would be the most you could store in the prop's hub ram based on the incoming signal and the 128 speed factor.
    The output audio can be easily handled by the prop but it might be worth considering one of the 12bit serial (I2C) ADC's ($2 – 3 dollars) capable of higher sampling rates for the input side.
    edited 2013-01-17 23:37
    A 12-bit serial ADC, sampling at 1.28 MHz, would have to have a clock rate exceeding 15 MHz. That's well beyond what I2C is rated at.
    edited 2013-01-18 00:28
    I think you will find that audio at 6 bits can be quite acceptable.
    Given that the signal we want to perceive here is not music or speech but rather some horrible squawks from a machine one might never notice the difference between 6 or, say, 12 bits.
  • TorTor Posts: 2,010
    edited 2013-01-18 01:24
    I think the idea is great. A bit like when we put an FM radio nearby a computer in the old times, to listen in to what it was doing.. it's just so easy to hear when something suddenly changes in a subtle way. Audio is great for detecting small changes.
  • Christof Eb.Christof Eb. Posts: 1,487
    edited 2013-01-18 03:58
    Hi,
    in the past I have done some sound processing with the prop. You will need to use pasm or a compiler. I used PropBasic.
    I would recommend to use an external ADC. The onboard ADC does not deliver its calculated number of bits as resolution. I want to say there is some amount of noise.
    There was a Parallax Oscilloscope using the Propeller. I don't have one but I think this could be hacked to do the job?
    Good luck, Christof
  • RaymanRayman Posts: 15,908
    edited 2013-01-18 06:40
    I've have this old "Parrot" demo program that might be a starting point...
    It records via microphone and then plays back later...
    Parrot_8bit.zip
    edited 2013-01-18 08:25
    Heater. wrote: »
    Given that the signal we want to perceive here is not music or speech...
    That's right, fidelity is not a big issue. It's just a matter of getting a general sense of things.
    Rayman wrote: »
    Hey, this sounds like fun. Thanks for the code!
    edited 2013-01-18 09:25
    My mistake, that should have been SPI, not I2C, and there are several inexpensive serial and parallel 8, 10, and 12 bit ADC,s available that would handle that sample rate. In many cases the 12 bit ones are less expensive than the 8/10 bit ones.
    If I were looking at doing something like this I would probably go for a 12 bit parallel ADC even though I may only use 8 or 10 of the bits. It makes for much simpler signal acquisition code.
    edited 2013-01-18 12:54
    kwinn wrote: »
    ...I would probably go for a 12 bit parallel ADC even though I may only use 8 or 10 of the bits. It makes for much simpler signal acquisition code.
    Okay. Makes sense to me. But I'm guessing I would need some sort of external memory to help store data before it gets played back. Any suggestions on what's fast enough to do that? jmg suggested SPI SRAM. Do you think the Prop could manage all the reading/writing/reading that would be necessary in real time using 12 bits?
    tonyp12 wrote: »
    Hey thanks! It's a nice resource.
    edited 2013-01-18 13:20
    Since the 'weakest link" will be in the level of audio quality that you want to play back, then that's as far as you need to go in terms of storage. Sure you can sample the data really fast and perform ensemble averaging to quantify the data, but the rate of storage only needs to be that of the quality you want to play it back. Just store the quantified data.
    edited 2013-01-18 14:16
    Another memory option is Atmel Dataflash. It has two RAM buffers. As one is being burned to flash the other is being filled with new data.
    If it can be "heard" real time, there are techniques suggested for Bat Detectors...
    The-Bat-detector-from-Nuts-and-Volts
    Audio-Frequency-Shifter-Hear-your-PING!
    edited 2013-01-18 16:12
    If you were using 8 or 10 of the 12 bits you could pack 10mS of data into hub ram but for 12 bits you would need external memory. Personally I would go for external memory. It does not add much cost and makes the resulting circuit more flexible.
    I have not used the quad serial SPI ram chips yet so have no actual experience with them, but from the data sheets it sounds like they would be ideal for this application. Once set up the propeller only needs to output the data and clock signals to the chip.
    edited 2013-01-18 16:47
    .. But I'm guessing I would need some sort of external memory to help store data before it gets played back. Any suggestions on what's fast enough to do that? jmg suggested SPI SRAM. Do you think the Prop could manage all the reading/writing/reading that would be necessary in real time using 12 bits?
    12 bits at 1.25Msps is at least 15MHz, and that is pushing into the realm of tricky. (but not impossible)
    Ideally, you want a Continuous conversion ADC that does not need extra trigger pins - not easy to find.
    20MHz gives 16-clock frames at 1.25MHz, and the prop can give a 20MHz CLK, which is the SPI RAM limit.
    Devices like the ADS7883/4/5 show some of the fish-hooks : SPI and 3Msps and an ok price...
    but it has a CS/Start pin, with strict duty needs, and has a 16 clock frame..
    The AD7276 looks is slightly more tolerant, but that timing still looks a challenge.
    The Prop Counter module can also output carry pulses, which will be 12.5ns wide, at any rate you choose, so /4/16 would give the 1.25Msps trigger, but the AD7276 data is vague if that is legal.
    I think it is ok on tQUIET, t1, t2 - something that would need a bench test methinks.
    Then the phase of the CS and CLK will determine the offset of the data blocks in the SPI stream.
    The Prop has no atomic control of both Counters, but you may be able to start them in a known phase with care.
    CS without CLK looks legal so perhaps Start CS, wait-SW-sync on that, then start CLK, and it may be the first field is discarded.
    Play back has to ping-pong with record.
    The CLK line is SW controlled to prime the SPI memory : set address and write command, and then ready for whatever trigger you use to flip into Hardware control of SPI CLK.
    edited 2013-01-18 17:39
    jmg,
    OMG, my brain just exploded!
    edited 2013-01-18 20:10
    Would there be any shame (or benefit) in having an ADC that would output results via parallel output instead of serial? Just poking around, and just as an example, I came across this AD7822, which advertises 8-bit resolution at 2M samples/sec. Would something like that work faster? I really don't know what I'm talking about with ADCs, so I'm just tossing this out there.
    http://www.digikey.com/product-detail/en/AD7822BNZ/AD7822BNZ-ND/996997
    @jmg, I'm still recovering from information overload in your previous post, still taping my brain back together. If I knew only half of what you were talking about, I'd probably feel compelled to get a real job for once.
    edited 2013-01-18 20:27
    It may not be 'faster', but is it likely to be easier to get working.
    Ideally, you want an ADC that gives a new result, per clock, and does not have complex hand shaking.
    ie The TI ADC1175 may be easier than that AD7822
    ADC1175 says this
    Data is acquired at the falling edge of the clock and the digital equivalent of the data is available at the digital outputs 2.5 clock cycles plus tOD later. The ADC1175 will convert as long as the clock signal is present at pin 12.
    I did warn it was pushing into the realm of tricky, and of some fish hooks, but not impossible... ;)
    edited 2013-01-18 20:48
    jmg wrote: »
    ie The TI ADC1175 may be easier than that AD7822...
    Thanks. I definitely need to start simple on this. :)
    edited 2013-01-18 21:23
    TI will sample some of these in smt format, just mount on a schmartboard or similar header. Cheaper and it works. Could wish for a smaller header pin than they use though, easier on the breadboard.
    FF
