How to detect sweat levels, humidity sensor maybe?
rwgast_logicdesign
ould a humidity sensor be strapped on the body to detect how much is sweating, or would direct contact to water like this just give faulty readings? Maybe im barking up the wrong tree, if so anyone knoww of a sensor i could use to try and measure prespiration?
I don't think a humidity sensor would give very accurate readings for this type of use.
thank ncc, id acually only looked at the parallax offerings. In this case money isnt a huge issue within reason (ie probably not over 60 bucks). What is an issue is spending money on something that doesnt work. I thought a 9 dollar parallax sensor may be a good starting point for tests, to see if forking real money over is worth it.
SRLM, yes testing resistance may be the best way. It wont give a highly accurate reading but it should give a fairly ball park figure which may be good enough with other sensor data taken in to consideration.
Perhaps google for this test may help.
http://en.wikipedia.org/wiki/Sweat_test
Such google search shows that the quantity and composition of sweat may vary widely , in physiology and pathology.
BTW : Bioingeneers have designed a lot of quick diagnostic tests in past years , is it necessary to add more ?
