PropClip pin stuck...
MacTuxLin
Got these a while back but started to use this only recently. After a few uses, 1 pin got stuck. I don't want to use a pincer or a sharp object to push it out as I might damage the side thin wall around the pin. Anyone encounters this & what's the best option? Lubricant? Wait?
I think a bit of contamination or solder flux may have gotten in there.
I would try some 92% isopropyl rubbing alcohol might work. Or something stronger like acetone.
Duane J
Thanks Duane. I have something similar. I'll spray to clean these pin once a while after some use & add a little lubricant as well.
