Got these a while back but started to use this only recently. After a few uses, 1 pin got stuck. I don't want to use a pincer or a sharp object to push it out as I might damage the side thin wall around the pin. Anyone encounters this & what's the best option? Lubricant? Wait?
Thanks. I thought so but if it is still stuck, was thinking of using a hot-air gun to slightly increase the temperature of the side wall & hopefully it will expand enough to let the pin spring back up again. Seems these pins needs lubricant once a while.
I'm not so sure lubricant is the answer.
I think a bit of contamination or solder flux may have gotten in there.
I would try some 92% isopropyl rubbing alcohol might work. Or something stronger like acetone.
Duane J
Thanks Duane. I have something similar. I'll spray to clean these pin once a while after some use & add a little lubricant as well.
