Request for Forum Moderators to move P2 threads to this forum
                    Hello there,
As you can see we've got a bit of forum rearrangement underway!
I'd like to ask our Forum Moderators to relocate any P2 threads to this forum. Everything from Beau's blog to DE2-115 testing should be moved here if it pertains to the P2.
Anybody can reply to this thread to help identify what needs to be moved here, as David Betz has done below (thanks David).
http://forums.parallax.com/showthread.php/144384-p2load-A-Loader-for-the-Propeller-II
Why this thread are not moved.
http://forums.parallax.com/showthread.php/125543-Propeller-II-update-BLOG
http://forums.parallax.com/showthread.php/144797-P2-Spin-creating-P1-standalone-objects?p=1152818#post1152818
Little more
http://forums.parallax.com/showthread.php/144674-P2-pin-output-question
http://forums.parallax.com/showthread.php/144677-Announcing-CLMM-(pronounced-as-Clem)-Execute-Code-from-the-CLUT
http://forums.parallax.com/showthread.php/144675-Challenge-Execute-Prop-II-code-from-it-s-CLUT-space-(CLMM)
http://forums.parallax.com/showthread.php/144769-Where-are-the-complete-Propeller-II-specs
http://forums.parallax.com/showthread.php/144599-Announcing-P2BEE-Propeller-2-Bytecode-Execution-Engine
http://forums.parallax.com/showthread.php/144643-Propeller-II-emulation-for-Idiots
http://forums.parallax.com/showthread.php/145063-Sapeiha-s-Propeller-2-Base-Boards-DEO-Nano-Single-Cog-Emulator
http://forums.parallax.com/showthread.php/144281-Why-get-the-P2-Emulator
http://forums.parallax.com/showthread.php/144478-LMM2-Propeller-2-LMM-experiments-(50-80-LMM2-MIPS-160MHz)
http://forums.parallax.com/showthread.php/126544-Propeller-2-Preliminary-Feature-List
http://forums.parallax.com/showthread.php/141706-Propeller-II
http://forums.parallax.com/showthread.php/141952-SD-Card-Test-(Please-test-may-be-used-for-boot-code-for-the-Prop2)
More links.
http://forums.parallax.com/showthread.php/112209-Questions-To-Chip-on-Prop-2
http://forums.parallax.com/showthread.php/99467-Possiblity-to-add-more-COG-ram-to-Prop-II
http://forums.parallax.com/showthread.php/138857-Propeller-2-PAL-Standards-what-is-in-mind
http://forums.parallax.com/showthread.php/131477-GCC-Eclipse-and-Propeller-2-seeking-developers
http://forums.parallax.com/showthread.php/134185-Help-Chip-with-design-of-Prop-II
http://forums.parallax.com/showthread.php/132594-Propeller-II-Experimenters-PCB-requirement-s
http://forums.parallax.com/showthread.php/128480-Chip-has-a-Propeller-2-key-functions-test-chip.-.-.
http://forums.parallax.com/showthread.php/117789-Prop-II-on-chip-development-question
http://forums.parallax.com/showthread.php/126928-Propeller-II-(Chat-with-CHIP)-__-Some-extra-questions-will-come
http://forums.parallax.com/showthread.php/123535-Any-new-Prop-II-videos
http://forums.parallax.com/showthread.php/121647-Prop-II-CLUT-ram-and-RDQUADL-WRQUADL-OR-How-fast-can-you-reload-a-Prop-II-C
http://forums.parallax.com/showthread.php/131434-Prop-II-Speculation-amp-Details...-Will-it-do-what-you-want
http://forums.parallax.com/showthread.php/120187-How-close-is-the-propeller-v2
http://forums.parallax.com/showthread.php/117940-MOV-Reverse-Ideas-to-Chip-Gracey-(Parallax)
http://forums.parallax.com/showthread.php/118021-prop2-instruction-request-quot-mod-of-sqr-quot
http://forums.parallax.com/showthread.php/117762-Important-Prop-II-info
http://forums.parallax.com/showthread.php/116084-Propeller-II-news
http://forums.parallax.com/showthread.php/96956-Prop-II-maybe-Prop-III
What about place Propeller 2 forums link in --- Propeller 1 --->
[h=2]Sub-Forums[/h]As most of new users don't know of its existence and even old ones that don't find Propeller 2 threads don't know what happens.
