VB.net and the Spinneret — Parallax Forums
electromanjelectromanj Posts: 270
edited 2012-12-28 18:48 in Accessories
Hello. I have done a few projects with .net and the Propeller, and now that I am getting started with the Spinneret I was wondering how one would go about using a .net program with the Spinneret. I have gone through Mike g's tutorial (thanks Mike), and now I'm wondering if I would be able to use a .net application like below to control the Led? Any ideas where to get started?
Thanks.
  • Mike GMike G Posts: 2,702
    edited 2012-12-27 15:13
  • electromanjelectromanj Posts: 270
    edited 2012-12-28 10:10
    Here's what I have so far. Turns the led on and off , and receives the state. I used Visual Basic 2010 Express.
    Public Class Form1
        Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs)
        End Sub
        Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
            Dim request As System.Net.HttpWebRequest = System.Net.HttpWebRequest.Create("http://192.168.1.79:8080/led/23/off")
            Dim response As System.Net.HttpWebResponse = request.GetResponse()
            Dim sr As System.IO.StreamReader = New System.IO.StreamReader(response.GetResponseStream())
            Dim sourcecode As String = sr.ReadToEnd()
            TextBox1.Text = sourcecode
            TextBox1.BackColor = Color.White
        End Sub
        Private Sub onbutton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles onbutton.Click
            Dim request As System.Net.HttpWebRequest = System.Net.HttpWebRequest.Create("http://192.168.1.79:8080/led/23/on")
            TextBox1.BackColor = Color.Orange
    314 x 316 - 14K
    315 x 311 - 14K
    edited 2012-12-28 12:35
    Cool... easy-peasy
  • doggiedocdoggiedoc Posts: 2,250
    edited 2012-12-28 14:01
    Really awesome Travis! I wish I had the brain cells left to figure that stuff out!
    Paul
    edited 2012-12-28 17:04
    I've been building Browser based gadgets for communicating with the Spinneret/WizNet.
    Do folks want to see application based templates and gadgets?
  • WildatheartWildatheart Posts: 195
    edited 2012-12-28 17:23
    @ Mike
    Sooner rather than later, please.
    Also looking forward to seeing your work using the '5200. Thanks for sharing your knowledge and experience with us.
    You bet! All info is appriciated!
