It's against forum rules to cross-post. Your other thread with the same title will be deleted. Theoretically, the Propeller Servo Controller could be used to drive PING sensors. I seem to recall some problems people had with some 5V sensors and the Servo Controller because of the voltage level translators used, but I'm not sure if that was the PING or some other sensor. From a software standpoint, it's a "no brainer", but you'd have to either modify the existing servo control software or write your own using existing library objects for servo control and PING sensing. Look in the Propeller Object Exchange for the objects.
I'm now playing with this myself, I tried to bring down the voltage of the red and black outputs to 5 v with a voltage regulator but no luck< anybody have some more ideas?
