Anyone have a barebones example of generating PWM using PropBASIC? — Parallax Forums
MicksterMickster Posts: 2,846
edited 2013-02-02 09:26 in Propeller 1
I need to drive a motor and I have it somewhat working but not perfectly. Using "Countera Mode 32"
Mickster
  • BeanBean Posts: 8,129
    edited 2012-12-22 16:31
    Mickster,
    You probably want to use mode 48 (DUTY) instead of 32 (PWM).
    The PWM mode creates pulses that are very narrow and will not drive a motor very well.
    This code will use a speed from 0 to 255
      OUTPUT motorpin
      COUNTERA 48, motorpin
      DO
        ' Other code here
        FRQA = speed << 24
        ' Other code here
      LOOP
    P.S. I haven't tried the code above, but it should be close.
    Bean
    [/code]
  • MicksterMickster Posts: 2,846
    edited 2012-12-22 16:49
    Thanks Bean....Yeah I came across similar code that you provided as an example for driving an LED but I thought that Mode 32 was the one to use. How do I get more than 8 bits of range though?
    Mickster
    edited 2012-12-22 18:15
    I got it...This works and gives me > 16 bits of speed range. PWM (in Viewport) is looking as it should. PropBASIC is the only way to go!!!!!!!!!!!!!!!!
    Start:
    RDLONG 0, Delta
    COUNTERA 32, MotPlus,0,1
    Delta = Delta >>10
    Target = Cnt + Delta
      Do
          PHSA = -20000           '~25% Duty cycle
          WaitCnt Target, Delta
      Loop
    END
    I realize that this is low frequency stuff but, in this application I need to LPF it and generate a +/- 10v motor command.
    Mickster
  • pmrobertpmrobert Posts: 677
    Thanks Mickster. I had a need for variable PWM freq, DC and duration. Your code helped me get my head wrapped around how the counters work.
    -Mike
