Anyone have a barebones example of generating PWM using PropBASIC?
Mickster
I need to drive a motor and I have it somewhat working but not perfectly. Using "Countera Mode 32"
Mickster
Mickster
You probably want to use mode 48 (DUTY) instead of 32 (PWM).
The PWM mode creates pulses that are very narrow and will not drive a motor very well.
This code will use a speed from 0 to 255
OUTPUT motorpin COUNTERA 48, motorpin DO ' Other code here FRQA = speed << 24 ' Other code here LOOPP.S. I haven't tried the code above, but it should be close.
Bean
[/code]
Mickster
Start: RDLONG 0, Delta COUNTERA 32, MotPlus,0,1 Delta = Delta >>10 Target = Cnt + Delta Do PHSA = -20000 '~25% Duty cycle WaitCnt Target, Delta Loop ENDI realize that this is low frequency stuff but, in this application I need to LPF it and generate a +/- 10v motor command.
Mickster
-Mike
