HB-25 equivalent at 24v?
Oldbitcollector (Jeff)
It appears that 24v motors are out of range for HB-25
Does anyone know of a 24v equivalent?
Jeff
Jeff
Dimension Engineering makes a series of motor controllers that can handle 24V.
There is also the TI Jaguar Controller - only $60 now!
Yes, getting a 24V or higher drop-in for the HB-25 might be tough. For use with those motors, I have one of these $4 L298N-based controllers (2 ch, 35V, 2A peak) but haven't tried it yet. Of course it wants PWM input, not servo commands. Hope to try over Christmas break, will report back.
http://www.ebay.com/itm/110942422752
I second Dimension Engineering. I've used their Sabertooth 60X2 for a robot that weighs ~500lbs without any sort of trouble.
Dave
The amps at start are expected to be high.
Jeff
That's a great price on the L298N boards. I'm pretty sure that's about how much I spent for just the L298N chips plus the diodes.
My Rover 5 Mecanum robot uses L298N controllers. I think they work fine but Gordon doesn't like the L289 for motor control. I think he said something about too much of a voltage drop? I intend to investigate this. I may use one of Pololu's H-bridge boards.
Speaking of Pololu, they have a board that can handle 24V. It's on sale right now for $36.
Percentage-wise, losing 2 volts is less significant at higher voltages. At low voltages, zero voltage drop relays come on strong!
You would want to find out the stall current before choosing the controller.
agfa
