Switched-Reluctance Motor — Parallax Forums
CircuitsoftCircuitsoft Posts: 1,166
edited 2012-12-16 08:33 in Propeller 1
Much of the Gold Standard discussion has gone in the direction of Application Notes rather than peripherals. I wonder if it would be sensible for Parallax to find an up-and-coming technology that the prop can drive well.
In that vein, I would like to see a series of Application Notes on various motor drivers culminating in a Switched Reluctance driver. SR motors are difficult because they lack permanent magnets and need more precise switching, but that seems to be something the prop excels at, and is a direction many electric car drivetrain systems are looking due to Neodymium being mostly found in, and locked-up by, China.
Personally, I have no-to-little use for an SR controller, but I think it would be very attractive for industrial designers looking for an mcu.
  • jmgjmg Posts: 15,200
    edited 2012-12-14 22:27
    The Prop 2 has better timers, and faster clocks and task slicing, so I would imagine it would be very good for smart(er) motor drivers.
    Meanwhile, companies like TI also have fine-grained PWM control in parts like these :
    Device Series 	CPU Speed 	Memory 	         Features 	                 Starting Price (1ku)
    Piccolo F2806x 	90 MHz 	       128kB to 256kB 	Floating-point, VCU*,CLA*,DMA 	  $4.95
    Piccolo F2805x 	60 MHz 	       64kB to 128kB 	Fixed-point, CLA, PGAs, WinComp   $3.25
    Piccolo F2803x 	60 MHz 	       64kB to 128 kB 	Fixed-point, CLA* 	          $2.79
    Piccolo F2802x 	40-60 MHz      16kB to 64 kB 	Fixed-point 	                  $1.85
    and some include these
    12-bit ADC, up to 4.6 MSPS
    150-ps high-resolution ePWM
  • CircuitsoftCircuitsoft Posts: 1,166
    Yes, but given that you can do 160MHz-granularity PWM with the Prop 1, I suspect it's plenty powerful for most/all motor controller applications. While I'm planning to build a motor controller with it, I really don't feel I have the know-how to create an industrial-level application note.
    TI isn't the only motor-controller vendor. I know SiLabs does a lot of that as well, and there's certainly space for other silicon makers.
    Motor Controllers were always an application that seemed a perfect fit for the Prop's capabilities, so I'm surprised to not see more.
    Yes, Prop II will do it better, but Prop I should still be sufficient for some pretty impressive designs.
