Switched-Reluctance Motor
Much of the Gold Standard discussion has gone in the direction of Application Notes rather than peripherals. I wonder if it would be sensible for Parallax to find an up-and-coming technology that the prop can drive well.
In that vein, I would like to see a series of Application Notes on various motor drivers culminating in a Switched Reluctance driver. SR motors are difficult because they lack permanent magnets and need more precise switching, but that seems to be something the prop excels at, and is a direction many electric car drivetrain systems are looking due to Neodymium being mostly found in, and locked-up by, China.
Personally, I have no-to-little use for an SR controller, but I think it would be very attractive for industrial designers looking for an mcu.
Meanwhile, companies like TI also have fine-grained PWM control in parts like these :
TI isn't the only motor-controller vendor. I know SiLabs does a lot of that as well, and there's certainly space for other silicon makers.
Motor Controllers were always an application that seemed a perfect fit for the Prop's capabilities, so I'm surprised to not see more.
Yes, Prop II will do it better, but Prop I should still be sufficient for some pretty impressive designs.
