LMM2 - Propeller 2 LMM experiments (50-80 LMM2 MIPS @ 160MHz) - Page 4 — Parallax Forums
1246712
  • SapiehaSapieha Posts: 2,964
    edited 2012-12-10 15:07
    Hi Chip
    For Assembly programmers Little.
    For people that write GCC --- Can give big problems
    I think having to set the QUAD window at a QUAD-aligned address is a big pain. Do you guys agree? It keeps the circuitry simple but causes pain for the programmer.
  • AribaAriba Posts: 2,695
    edited 2012-12-10 15:08
    Can any of you think of any reason why QUAD registers should be assignable to 4 separate addresses, without concern for alignment? Just curious.
    This would be more flexible, you can for example do something like that:
    lmm  rdquad pc
    ins1 nop
    ins2 nop
         jmpd #lmm
    ins3 nop
    ins4 nop
         add pc,#16
    Andy
  • cgraceycgracey Posts: 14,292
    edited 2012-12-10 15:12
    Ariba wrote: »
    lmm  rdquad pc
    ins1 nop
    ins2 nop
         jmpd #lmm
    ins3 nop
    ins4 nop
         add pc,#16
    Andy
    Yes, that's what I was wondering about. Let me see...
    edited 2012-12-10 15:13
    Ariba wrote: »
    Andy
    I think this may work better:
    lmm  rdquad pc
    ins1 nop
    ins2 nop
    ins3 nop
         jmpd #lmm
    ins4 nop
         add pc,#16
    I don't mind such flexibility, as long as it does not slow things down...
    edited 2012-12-10 15:15
    i just lost my post :( so much for android!
    i was posting a way i thought you could separate the first serquad & readquad from the subsequent readquad loop so that each part could be verified.
    However i seechip has found a bug. Great work guys. much better to find this now. makes us happy chip released the emulation code.
    i am expecting to join you with the fun around xmas although sneaking away from the family might not go down so well.
    edited 2012-12-10 15:20
    It looks like it would be kind of messy at this point. I think I'll just make it so that there's one address that doesn't need to be quad-aligned.
    I figured you could do what you were attempting above like this:
    ins0    nop
    ins1    nop
    ins2    nop
    ins3    nop
            jmpd    #ins0
            add     pc,#16
            nop
            rdquad  pc
    edited 2012-12-10 15:28
    i can see it would be nice to be able to map the quads to any non-contiguous cog locations. however i would still be happy with the restriction they are on a 00 boundary and/or 4 contiguous, depending on the complexity. obviously bill & andy have worked a non-contiguous loop which is very clever for performing the lmm and this will be a major use in high level languages at least.
    i will be using readquads for fast loading of binary overlays.
    edited 2012-12-10 15:31
    Hi Chip.
    In my opinion ---> Most usable
    ins0    nop
    ins1    nop
    ins2    nop
    ins3    nop
            jmpd    #ins0
            add     pc,#16
            nop
            rdquad  pc
    edited 2012-12-10 16:18
    Sounds good!
    Could SETQUAD zero the cache registers? That way they would be guaranteed to execute as NOP's first pass through the loop.
    In the code below, would the rdquad ever execute? I thought JMPD only had two delay slots - or is my memory playing tricks on me?
    ins0    nop
    ins1    nop
    ins2    nop
    ins3    nop
            jmpd    #ins0
            add     pc,#16
            nop
            rdquad  pc
    ins0    nop
    ins1    nop
    ins2    nop
    ins3    nop
            jmpd    #ins0
            add     pc,#16
            nop
            rdquad  pc
    I also have no problem if the one cog address must be quad aligned. This is really a minor problem compared with the LMM code in hub ram, that must be structured in quad packets. I already can see a lot of nops in a GCC generated code.
    Andy
    edited 2012-12-10 16:21
    If you choose to make setquad clear the quad registers, please make it optional. I can see value in not clearing them every time you call setquad.
    Sounds good!
    edited 2012-12-10 16:23
    Sounds good!
    All delayed jumps have 3 delay slots - See also Chips post #50 in this thread.
    edited 2012-12-10 16:27
    Sounds good!
    There are three instruction slots that must be filled in a single-task JMPD scenario.
    I've been thinking about some way to clear the QUADs, as it would make things tidy. On cog startup, they contain the data loaded into $1F4..$1F7.
    Does anyone have any thoughts about SETQUAD clearing the registers? I have it set up now so that if you do a SETQUAD $1F8..$1FF the QUADs go into hiding. The hiding case might be a convenient time to clear the QUADs. Does anything think you might want to do a SETQUAD to simply move them, without clearing them?
    edited 2012-12-10 16:31
    Roy:
    The reason I'd like the quad cache cleared at a SETQUAD is so that a tight RDQUAD LMM loop will not execute random code.
    Andy:
    Thanks! Jeez my memory is going... or is that lack of sleep... or lack of cofee...
    Chip:
    Thanks, I don't know why I had a memory error on that. I'd better check my ECC bits.
    How about SETQUAD D wz means clear the cache, without wz does not clear it?
    The reason I'd like it cleared is the problem you pointed out many messages ago - the LMM look running random instructions on the first pass through the loop.
    edited 2012-12-10 16:35
    Hi Chip.
    I think that answer Yours last question.
    Hide ---> and clear --> BUT if moved to other position in COG -- leave as it is.
    Roy Eltham wrote: »
    edited 2012-12-10 16:42
    That does not work for what I need, I'd have to SETQUAD twice, once to hide it and clear it, and again to repositionit where I need it - every time the LMM2 loop is initiated.
    Frankly, I am still trying to figure out a case where it is useful to SETQUAD and NOT clear the cache... I am tring to find a use for that.
    Sapieha wrote: »
    Hi Chip.
    edited 2012-12-10 16:47
    I think the Prop2PreliminaryFeatureList - PDF speaks of 2 delay slots, so there's a big chance that your memory still is okay. ;)
    Andy
    edited 2012-12-10 16:48
    Here's a new configuration file for the DE0_Nano which fixes the QUAD mapping bug:
    Prop2_DEO_Nano_v2.zip
    I'll make a DE2_115 and StratixIII version a little later. I want to address the QUAD clearing issue and get REPS/REPD so that it works by task, not in general.
    edited 2012-12-10 16:52
    Hi Bill.
    Best case as I see it was Yours proposal.
    give all possibility's.
    My one as second one if other things not work.
    Roy:
    Andy:
    Chip:
    edited 2012-12-10 16:54
    Yes, Bill, I understand that, but there are uses for the cog besides running LMM kernels. ;)
    chip, I can't give you any real use examples right now, but I think it would be good if setquad could be called to move the quad mappings without clearing. So if it isn't difficult, I think clearing should be optional somehow. Is the NR/WR bit available?
    Roy:
    Hi Chip.
    Thanks.
    Good if REPx can work with task's --- Give more flexibility
    edited 2012-12-10 17:03
    Thanks Chip!
    Wifey is going to kill me... more Prop2 play time :-) :-) :-)
    REPS/REPD working by task would be great.
    edited 2012-12-10 17:12
    Roy Eltham wrote: »
    I agree, Roy. Integrating clearing somehow into SETQUAD would be nice. We've got the Z and C bits which I can cause not to do anything. Biggest problem is what do you call it? Seven characters, max, or you blow the tab stop. SETQUAD vs SETQUAZ or ZETQUAD?
    edited 2012-12-10 17:18
    This might sound dumb but can't we say SETQUAD for setting without clearing and the current SETQUAD would then be CLRQUAD?
    edited 2012-12-10 17:19
    Hi Chip.
    Why not simple.
    SETQUAD D, wz
    SETQUAD #n, wz
    Ps. else new directive
    rz
    edited 2012-12-10 17:21
    One of:
    Does not clear:
    SETQUAD D
    SETQUAD #n
    Does clear:
    SETQUAD D, wz
    SETQUAD #n, wz
    SETQUADZ D, wz
    SETQUADZ #n, wz
    edited 2012-12-10 17:35
    SETQM, and SETQMZ
    QM for Quad Mapping
    edited 2012-12-10 17:37
    Hi Chip,
    I just tried to re-program my Nano, and I got:
    "Error: File Z:/2012/prop2/Prop2_DEO_Nano_v2/DE0_Nano_Prop2.jic is corrupted"
    I donloaded the zip twice, an tried it about four times.
    Help!
    edited 2012-12-10 17:39
    Hi Roy
    I think it will be more flexible if it can be organized in same MNEMONIC with adding only extra directive
    wz --- Else if Chip make new one ---- Flush
    Roy Eltham wrote: »
    SETQM, and SETQMZ
    QM for Quad Mapping
    edited 2012-12-10 17:40
    Hi Bill.
    I don't had any problems with reprograming
    Hi Chip,
    Help!
