Mapping an area then storing it for later use?
rwgast_logicdesign
Is it common to get a robot wandering and then use a bunch of sensors, sonar, bumper ir, etc to create some kind of cad like map of the area it travels in then store it to memmory, sd/eeprom/flash chip whatever? I think this could be a really cool way to save power so when your robot is just roaming around a known area it can shut down all of its sensors and pan/tilts etc then just focus on whatever the task at hand may be. Im wondering if this is something common and I just dont know the name name for it. I just ordered a compass last night, I think along with an array of object detection and distance sensors this would be pretty feasible its just coming up with a file format and algorithm to do the mapping, dont want to reinvent the wheel if this is a common place feature and im just not sure what its actually called.
This has been done a bunch of different ways but it's not simple.
Here's a thread where it was discussed a bit.
This isn't really mapping, but I did record the path my robot took so it could replay it here with my PropBOE-Bot (I was copying something erco had done with the BS2).
Having a robot make and use a map is one of my robotic goals.
John Abshier
I like beacon nav. The beacons can be used to get the robot to the desired area and on the way all the normal avoidance routines can deal with the mess of real life even minus a map. Mapping could then be used to enhance the avoidance and the beacons then give a solid reference for orientation and if you can see multiple beacons you can even triangulate for position.
This was done in the Micro Mouse Races in the mid/late 70's. The objective was to have the mouse travel through a maze to the exit as quickly as possible. Initially the mapping consisted of 1 bit per square area of the maze (like a pixel on a screen) with a 1 representing a clear area. Simple to program and worked well when there was an initial learning run or multiple timed runs, but as speed increased wheel slip made it less useful.
Still doing it in this millennium!
"Honey, I'm removing three inches from the sofa so our robot doesn't get lost."
Thanks for posting that. I didn't think maze races were still around. All I have seen lately were line follower contests.
@Duane
Back when I was involved memories were pretty small and expensive so the "pixels" were a square with dimensions equal to the width of the maze passages. With what's available now you could probably map your entire house at 1 inch or better resolution so there is no need to modify the furniture ;-)
I work with kids who have cerebral palsy... many of them struggle to control their wheelchairs and as a consequence they can't go anywhere by themselves. The prices people pay for new wheelchairs that don't do anything more than move ... is obscene. On the other hand... there are more wheelchairs than there are people that need them... and most of those aren't worth spit to the people that really need them. My front room is now full of $100 electric wheelchairs that I bought on EBay:)
What does this have to do with mapping? If you want a fully autonomous wheelchair with occasional human input... you need mapping and a bunch of sensors. And really good control of the wheels.
